Thread Closed
Spacing of Riemann's Zeros
Share Thread Thread Tools
Apr29-07, 05:06 AM   #1
I've just been reading through my number theory lecture notes and I noticed this line of reasoning:
***Assuming the Rieman hypothesis***
[tex]\sum_{\gamma > 0}\sin(\gamma \log x) \frac{-(1/2)^2}{\gamma((1/2)^2 + \gamma^2)} = O(1)[/tex]
by comparisson with [tex]\sum_{n \ge 1}\frac{1}{n^2}[/tex].
Let me explain the context a little. Importantly the gamma are the non-trivial zeros of the zeta function in the upper half plane. (The goal is to obtain an expression which demonstrates a connection between the Von-Mangolt explicit formula and Fourier series if anyone's interested but that is really not important for my question.)
Now as far as I can see the statement is true by considering absolute convergence etc. but surely this requires also that the spacing of the zeros on the line Re(z) = 1/2 is sufficenty sparse so that the comparison is valid.
There is no mention anywhere else in the course of this being a fact. Is it true?
How much do we know about properties of the distribution? I suppose the above question concerns the existence of a lower bound on the spacing.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Apr29-07, 05:31 AM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by Diophantus View Post
It sounds wrong, but I've only looked at small zeroes.
Apr29-07, 02:09 PM   #3
tpm
If in V.Mangoldt formula you put x=exp(u) and differentiate respect to 'u' setting [tex] \rho _{n} = 1/2+it_{n} [/tex] you can find an expression for:
[tex] \sum_{n} exp(it_{n}) [/tex] similar to a kind of sum over 'frecuencies' where the 't'-s are just the imaginary part of NOn-trivial roots.
May1-07, 12:25 PM   #4
Ok to simplify the situation a little, it has been claimed to me that
[tex]\sum_{\gamma > 0}\frac{1}{\gamma^2}[/tex]
is convergent, where, as usual, the gamma are just the imaginary parts of the Riemann zerosin the critical strip.
I think this is false based on the following heuristic arguament:
The number of Riemann zeros in critical strip between 0 and iT is known to be asyptotic to Tlog(T)/2pi. It follows then that the average density becomes unbounded as we go further up the strip, and hence the series must diverge.
If I am correct, how might I go about proving this?
May1-07, 06:03 PM   #5
Recognitions:
By finding an asymptotic upper bound on the n-th zero, and thus a lower bound on the series. If the lower bound on the series is infinity...
Are you sure that gamma is the imaginary part, and not the actual value of the zero? You said otherwise in your OP.
May1-07, 07:37 PM   #6
Recognitions:
Homework Helper Homework Help
The average density tending to infinity does not imply the series will diverge. How fast it tends to infinity is important. Here, you only have log(T) times as many zeros up to T as you do integers (ignoring constants and lower order terms), which really isn't that much, and not enough to make this diverge.
Try bounding the tail of the series by looking at
[tex]\sum_{T+t \geq\gamma > T}\frac{1}{\gamma^2}[/tex]
and smacking it around with partial summation and your asymptotic for the number of zeros (really the bound O(Tlog(T)) for the number of zeros will do). Let "t" go to infinity and you should be able to get something that shows the tail tends to 0 as T->infinity, so the original series converges.
For Hurkyl's question about gamma, it doesn't really matter here if it's the imaginary part or the whole zero for the convergence of this series. The real part will be between 0 and 1, while the imaginary part is tending to infinity, so the real part doesn't do much. However, the usual convention is little gamma standing for the imaginary part, so that's likely what they were talking about.
Thread Closed
Thread Tools
Similar Threads for: Spacing of Riemann's Zeros
Thread Forum Replies
d-spacing physics help Biology, Chemistry & Other Homework 1
Interplanar spacing 'd' General Physics 1
Riemann's interest in physics General Physics 2
Riemann's Translucent ball General Math 4
