Can a 'periodic' function be used to derive these two sums using Fourier series?
This discussion focuses on the derivation of two specific sums using Fourier series, specifically the sums \(\sum_{k=1}^{\infty} \frac{\coth{(\pi k)}}{k^{3}} = \frac{7 \pi^{3}}{180}\) and \(\sum_{k=1}^{\infty} \frac{(-1)^{k+1}}{k^{3} \cdot \sinh{(\pi k)}} = \frac{\pi^{3}}{360}\). The user, Nasim, seeks to explore whether these sums can be derived using a piecewise smooth continuous periodic function, potentially a parabolic and linear waveform. The discussion includes complex analysis techniques for deriving the sums but emphasizes the desire for a Fourier series approach.
  • Understanding of Fourier series and periodic functions
  • Knowledge of complex analysis, particularly contour integration
  • Familiarity with hyperbolic functions such as \(\coth\) and \(\sinh\)
  • Basic calculus, including the concept of piecewise functions
  • Research the properties of piecewise smooth continuous functions in Fourier series
  • Study the application of contour integration in deriving sums
  • Learn about the relationship between hyperbolic functions and Fourier series
  • Explore examples of parabolic and linear waveforms in Fourier analysis
Mathematicians, physicists, and students interested in advanced calculus, particularly those focusing on Fourier series and complex analysis techniques for deriving mathematical sums.
nasim
Hello... How can I find an appropriate 'periodic' function (associated with a
Fourier series) to derive the following 2 sums?
[tex]1. \displaystyle \sum_{k=1}^{\infty} \,\,\, \frac{\coth{(\pi k)}}{k^{3}} \,\,\, = \,\,\, \frac{7 \pi^{3}}{180}[/tex]
[tex]2. \displaystyle \sum_{k=1}^{\infty} \,\,\, \frac{(-1)^{k+1}}{k^{3} \cdot \sinh{(\pi k)}} \,\,\, = \,\,\, \frac{\pi^{3}}{360}[/tex]
PS: I know how to derive both the above sums using complex analysis,
i.e. for [1], I use
[tex]f(z) = \displaystyle \oint_{C_k \in \Box \;\ni\; k \to \infty} \,\,\, \frac{\cot{\pi z} \cdot \coth{\pi z}}{z^{3}} \;\;\; dz[/tex]
on a 'square' contour centered around z=0, and with poles at z=0 (of order 5),
[tex]\pm1[/tex] (and all the rest are 'simple' poles), [tex]\pm2, \pm3, \pm4,... \pm{i}, \pm{2i}, \pm{3i}, \pm{4i},...[/tex]
and for [2], I use
[tex]f(z) = \displaystyle \oint_{C_k \in \Box \;\ni\; k \to \infty} \,\,\, \frac{1}{z^{3} \cdot \sin{\pi z} \cdot \sinh{\pi z}} \;\;\; dz[/tex]
on a similarly defined contour.
But I wanted to know if it can also be done using a properly defined choice of
[tex][x_0, x_0+T][/tex] piecewise smooth continuous 'periodic' function f(x),
e.g. perhaps a parabolic+linear waveform associated with a Fourier series...
that might look something like:
[tex]\displaymath f(x) = \left\{ \begin{array}{lll} ax^{2}+bx+c,& x_0 \leq x < x_0+\frac{T}{2}& [\,\,a,b,c \in \mathbb R\,\,] \\<br /> px+q, & x_0+\frac{T}{2} \leq x < x_0+T& [\,\,p,q \in \mathbb R\,\,] \end{array} \right \displaymath[/tex]
I would like to know the values (zero/non-zero) for [tex]a,b,c,p,q = \,\,\,?\,?\,?[/tex]
Thanks much.
---Nasim
Maybe this explanation helps:
  • · Replies 33 ·
