Mixing household bleach with urine |
Apr30-07, 05:24 PM
#1
jmnew51 is
Offline:
Hello everyone,
Not that I looking to experiment or anything, but anyway...correct me if I'm wrong anywhere here...please.
An associate of mine was wondering how to get rid of cat urine smell. Having exhausted all attempts to cover it up or use that enzyme stuff, I told him I usually treat the offending area(because I have 3 cats, I know)with a solution of household bleach. The ensuing reaction liberates alot of chlorine gas and that he should leave the area for a short time as chlorine gas is very irritating. (I do this all the time, and my kitties love me)
A friend strongly advised him not to mix bleach with urine because urine has ammonia in it. And the gas is toxic and will kill you.
Well first off I don't think urine has ammonia in it because urine is acidic. (Uric acid). The ammonia you smell from a cat's litter box is from the decomposition of the nitrogen rich by-products of metabolism. Correct so far?
Secondly the gas is chlorine because sodium hypochlorite is an oxidizer and it gives up it's oxygen in the process and liberates chlorine as a by-product.
Third the reaction is also somewhat of a typical acid-base reaction because bleach has a high ph and urine has a low ph.
I don't think I'm too far off base with the description of the reaction, or the origin of that ammonia smell, am I??
Please someone correct me if I'm wrong.
Also just out of curiosity, what would be the final products of a reaction with an oxidizer like sodium hypochlorite and uric acid and urea?
Carbon dioxide, water, sodium chloride. hmmmmm...where does all that nitrogen go??
Also what would the result of mixing ammonia and bleach? Hmmmm...?
I know it doesn't smell good, but do they even react?
Thanx for looking
Jim
Apr30-07, 05:45 PM
#2
turbo-1 is
Offline:
Thanx for looking
Jim
You're kidding, right? You should immediately Google on "ammonia and bleach" for your own safety.
Apr30-07, 06:14 PM
#3
jmnew51 is
Offline:
I figured chloramines were one of them. No, I have never mixed bleach and ammonia intentionally. Only accidentally once then immediately poured out he mix because like I said it didn't smell good.
Just mainly wondering about the danger of using a mild bleach solution to clean up after a cat?
Apr30-07, 08:35 PM
#4
gravenewworld is
Offline:
there is probably no harm in cleaning up cat urine with bleach. i've worked with stuff like pure chlorine gas before and accidently breathed some in, but I am fine.Just work in a ventilated area in and you will be ok.
Jul1-07, 11:02 AM
#5
skippir is
Offline:
Mixing bleach and ammonia can be extremely dangerous
Per a quick Google search to verify:
There are several ways household ammonia and bleach can react. All of them are dangerous.
Reaction type 1: Ammonia directly reacts with bleach to form hydrazine (N2H4, which, in addition to being extremely poisonous, can burn even in the absence of air! It explodes on contact with rust!
2NH3 + NaOCl -----> N2H4 + NaCl + H2O
Reaction type 2: Bleach hydrolyzes into sodium hydroxide and hypochlorous acid, which in turn decompose into chlorine gas and nascent oxygen (both poisonous). The chlorine gas in turn reacts with the ammonia to form chloramines, also very poisonous.
NaOCl -----> NaOH + HOCl
HOCl ---> HCl + O (monatomic oxygen)
NaOCl + 2HCl -----> Cl2 + NaCl + H2O
2NH3 + Cl2 -------> 2NH2Cl (chloramine)
4NH3 + 2Cl2 ------> 2NHCl2 (dichloramine)
6NH3 + 3Cl2 ------> NCl3 (trichloramine or nitrogen trichloride)
{some of these chemicals have effects similar to phosgene gas on lung tissue and other mucous membranes}
Jul11-07, 07:08 PM
#6
victorvp is
Offline:
You once mixed ammonia and hypochlorite "accidently"? You really need to pay more attention to what you're doing. Not only are chloramine gases very toxic, trichloramine is a contact explosive. If anyone here has ever observed Nitrogen triiodide, you'll know exactly how dangerous this is.
Jul11-07, 07:32 PM
#7
jmnew51 is
Offline:
Yes, a household member of mine (don't want to mention any names) dispensed regular household ammonia into an empty spray bottle (for cleaning)labeled "bleach". I know, not good.
Well I dispensed what I thought was bleach into what I knew was bleach, then proceeded to dump the mixture out when I noticed something wasn't right.
This family member was immediatly instructed on the error of their ways.
I know about nitrogen triiodide. I made it once in high school. It has no practical purpose at all.
Thank you for all the advice everyone. I'm usually pretty careful, but I will be more carefull in the future.
Jim
Aug8-07, 05:53 PM
#8
scarecrow is
Offline:
Actually, humans and mammals excrete urea (not uric acid) in their urine. Birds usually excrete uric acid.
Urea is CO(NH2)2 (a structure analogous to acetone).
Aug10-07, 07:48 PM
#9
ShawnD is
Offline:
Recognitions:
Not much of a chemistry answer, but try using Borax.
Aug10-07, 10:27 PM
#10
jmnew51 is
Offline:
Hmmmmm....Borax, or sodium borate I beleive. What would be the reaction there?
Jim
Aug11-07, 12:54 AM
#11
ShawnD is
Offline:
Recognitions:
http://chemistry.about.com/od/howthi...boraxworks.htm
Borax has many chemical properties that contribute to its cleaning power. Borax and other borates clean and bleach by converting some water molecules to hydrogen peroxide (H2O2). This reaction is more favorable in hotter water. The pH of borax is about 9.5, so it produces a basic solution in water, thereby increasing the effectiveness of bleach and other cleaners. In other chemical reactions, borax acts as a buffer, maintaining a stable pH needed to maintain cleansing chemical reactions. The boron, salt, and/or oxygen of boron inhibit the metabolic processes of many organisms. This characteristic allows borax to disinfect and kill unwanted pests. Borates bonds with other particles to keep ingredients dispersed evenly in a mixture, which maximizes the surface area of active particles to enhance cleaning power.
So basically it's like Oxyclean.
Aug13-07, 06:16 AM
#12
kclo4x is
Offline:
I highly doubt that chlorine is released, its simply to reactive and its saying that NaOH is formed.... Wrong!
NaOCl does give up its oxygen but it makes NaCl, salt...
however dangerous chemicals are going to form, but for the small amount of urea that is in urine... i wouldn't worry about it!
even if your exposed to dangerous levels i'm sure you can heal because chlorine and i imagine similar chemicals do not leave long term effects
Aug13-07, 10:14 PM
#13
jmnew51 is
Offline:
I'm sorry. I guess I was wrong then.
Just the gas released when I squirt bleach solution to clean up after kitty smells an awful lot like chlorine, because I thought the uric acid in the urine was reacting with the hypochlorite to give off chlorine in some way.
I know urine eventually contains ammonia.
But does fresh urine actually contain ammonia?
Is urine acidic or basic?
Thanx
Jim
Aug13-07, 11:21 PM
#14
JGM_14 is
Offline:
fresh urine does not contain much ammonia due to the acidic condition of urine, you can usually tell by the smell, but the enzymes in the urine break down the urea to CO2 and ammonia over time, but if the conditions are changed to slightly basic, like with sodium bicarbonate, the production will be much quicker, unless you use a highly basic chemical like NaOH as it will denature the enzymes and possibly get rid of the smell, or prevent the smell, after that try a scented detergent.
I am not so sure about the bleach, but if it works, have good ventilation.
Aug23-07, 12:23 AM
#15
jmnew51 is
Offline:
It works real good.
But if there is an excess (of old urine), you best be hoping you're on your way out of there.
Jim
Sep22-07, 01:22 PM
#16
newcomen is
Offline:
I personally encountered the bleach/ammonia reaction when a hospital floor had to be evacuated in 1965. I believe that the same phenomenon was the cause of the Riverview Hospital (CA) emergency room incident in 1993 (bleach/urine reaction), the cause of which was never officially proven, and chloramine was never even considered by two investigative bodies.
