Understanding the Coanda Profile and Its Effects
  • Thread starter Thread starter Shridhar .S
    Effects
The Coanda effect describes how a smoke stream in a wind tunnel adheres to a surface that curves away from the flow direction, resulting in air being entrained along the surface due to reduced pressure. This pressure reduction occurs because the interaction of the flow with static particles in the boundary layer displaces them, leading to fewer particles and lower pressure. It is crucial to distinguish the Coanda effect from Bernoulli's equation, as the former involves unsteady flow interactions that violate Bernoulli's assumptions. Understanding these principles is essential for effectively managing buoyancy in fluid dynamics applications.
  • Understanding of fluid dynamics principles
  • Familiarity with the Coanda effect and its implications
  • Knowledge of Bernoulli's equation and its limitations
  • Basic concepts of pressure dynamics in airflow
  • Study the Coanda effect in detail using "Fluid Mechanics" by Landau & Lifshitz
  • Explore practical applications of the Coanda effect in engineering
  • Investigate the relationship between the Coanda effect and buoyancy management
  • Learn about the limitations of Bernoulli's equation in real-world fluid scenarios
Aerospace engineers, fluid dynamics researchers, and anyone involved in the design and analysis of aerodynamic systems will benefit from this discussion.
Shridhar .S
Can some one spread more light on coanda profile its effects ,calculations etc
The Coanda effect in air is the fact 1) a smoke stream in a wind tunnel follows a surface that gently curves away from the direction of the flow and 2) air from the main flow is entrained to follow the surface. It is caused by the reduced pressure at the surface. Why is the pressure reduced there? Because the interaction of the flow with the static particles in the boundary layer of the surface blows particles away from the surface. Fewer particles, lower pressure. If the Coanda effect could be used to reduce the pressure at the surface to 0 (a VERY ambitious task), there would remain 14.7psi pressure on the other side of the body. A VERY large pressure. To exploite the Coanda effect is to manage buoyancy.
Coanda effect
Some people conflate the Coanda effect and effects covered by Bernoulli's equation (a statement of the conservation of energy). Because the Coanda effect is caused by the shearing, unsteady flow near a surface, Bernoulli's equation doesn't hold. (See Landau & Lif****z "Fluid Mechanics" and read carefully the section on the Bernoulli equation.) Beware, this topic is very sensitive and rhetoric waxes religious in its fervor. There is nothing magic about the Coanda effect. It is well-known, so its existence isn't in question. Its explanation is, however. Hint: it is caused by the interaction of fluid particles with each other and with the surface. Bernoulli's equation assumes no such interactions.
23K
