Help with Adhesives: Bond Polycarbonate to Acetate
  • Thread starter Thread starter CaptainQuaser
The discussion focuses on finding a suitable adhesive for bonding polycarbonate to acetate, emphasizing the need for a strong, waterproof, and relatively thin adhesive. Participants explore various types of adhesives and their properties relevant to the task.
  • Experimental/applied
  • One participant suggests silicone as a potential adhesive but expresses uncertainty about its adherence to polycarbonate and acetate.
  • Another participant critiques silicone for being too thick and weak, indicating the need for a transparent adhesive that can withstand vibrational modes.
  • A participant recommends Weld-On #'s 3 & 4, noting their effectiveness on acrylic but not confirming their suitability for polycarbonate and acetate.
  • Cyanoacrylate is proposed as another option, though no specific experiences are shared.
  • One participant shares results from glue tests, indicating that Lepage 5 and Loctite 401 are the strongest candidates, with clarity being a significant factor.
  • A later reply mentions that Loctite 401 holds well but dries too quickly, complicating application.
  • Another participant introduces the idea of using a light cure instant adhesive, providing links for further exploration.
Participants express varying opinions on the effectiveness of different adhesives, with no consensus on a single best option. Multiple competing views on adhesive properties and suitability remain unresolved.
Participants mention specific performance criteria such as thickness, clarity, and resistance to vibrational modes, which may influence the choice of adhesive but are not fully explored or agreed upon.
CaptainQuaser
Hi
I need to find a strong bonding waterproof adhesive to attach polycarbonate to acetate. It must be relatively thin, and strong.
Any suggestions?
Have you tried silicone? I'm not sure how well it would adhere to those materials, but it's pretty universal. If it does work, you might want to use the 'bathroom repair' sort. It has an anti-fungal agent in it for use in damp environments.
Silicone is used for most of the cell, but is far too thick and week for this purpose. I am at home at the moment, but heading to the lab in a minute and I will post the glue tests I have tried, none have been particularly successful at the moment. Thickness is important, and it must be transparent to ultrasonic frequencies, and it must be strong enough not to allow buckling or vibrational modes into an acetate window.
This site might be of some help to you: http://www.tapplastics.com/info/adhesives.php?"
I used Weld-On #'s 3 & 4 fairly extensively in a couple of different occupations. They're awesome on acrylic, but I don't know about other materials. You just put the pieces together the way that you want and squirt it into the joint with a syringe. It diffuses along the whole contact area by capillary action--very thin and completely invisible. Despite what it says on that site about setting in 30-60 minutes, we found that it was ready to handle within 1-2 minutes.
Have you tried cyanoacrylate?
I have done glue tests on:
Loctite Stick,n Seal
Loctite 401
Marine Goop
Lepage 5
Gorilla Glue
i have two new ones being ordered in for tests
at the moment
Clarity is also important, and Loctite 401 seems to be the clearer than Lepage 5 which clouds pretty bad.
So i used Loctite 401 on one of the cell walls, holds tight, but it dries a little to fast for my liking, making it difficult to work with.
Maybe this combination light cure instant adhesive will do the trick. Just apply light when you're ready.
http://www.threebond.co.jp/en/technical/newtechnical/ultravioletrays/newtechnical2.html
http://www.loctite.com/int_henkel/loctite_us/index.cfm?verityspider=0&layout=4&productline=OEM6020&path=Assembly%20Products|Bonding|Light%20Cure%20Adhesives
As if my 'bookmarks' bar wasn't too long already... :rolleyes:
Nice link.
  • · Replies 22 ·
13K
  • · Replies 17 ·
