Limit of x^2/(y^2+x^2) at (0,0): Calculus Homework Solution
  • Thread starter Thread starter superdave
    Calculus
The problem involves evaluating the limit of the expression x^2 / (y^2 + x^2) as (x,y) approaches (0,0) and determining whether this limit exists.
  • Exploratory, Assumption checking
  • Participants discuss the need to evaluate the limit along different paths to determine its existence. Some mention using l'Hôpital's rule and partial derivatives, while others suggest specific paths such as y=x and y=0 for analysis.
There is an ongoing exploration of the problem, with participants sharing their thoughts on how to approach the limit and the implications of different paths. Some guidance has been offered regarding the method of checking limits along various paths.
Participants are considering the conditions under which a limit exists in multiple dimensions, particularly the requirement for consistency across different paths of approach.
superdave
Show that the following limit does not exist:
lim (x,y) --> (0,0) of x^2 / (y^2 + x^2)
I think it involves using l'hospitals rule and using partial derivatives, but I really don't know.
For a limit to exist in multiple dimensions, it must be the same no matter which path you approach the point from. So if (x,y) travels over, say, y=x to (0,0), if the limit exists, it must be the same as if (x,y) travels over y=0 to (0,0).
So try two paths, show the limit is different depending on how you approach (0,0), and you're done
I'm not really sure how to go about that
I know how to take partial derivatives and directional derivatives...
Set y=x, and see what the limit is when x->0. Then try setting y=0, and see what the limit is as x->0. This is the idea for proving any limit in multiple variables does not exist, just go along different lines, if you get different answers, the limit does not exist.
Ah, I ge tit now, thanks
