Calculate Velocity Using Bernoulli's Equation
  • Thread starter Thread starter grscott_2000
    Bernoullis
The discussion focuses on calculating velocity using Bernoulli's equation, specifically in the context of a flow rate of 5.00 m³/s and a pipe diameter of 0.6 m. The correct formula for determining velocity is established as velocity = 4 * flow rate / (π * (pipe diameter)²). The initial assumption that velocity is simply 5.00 m/s is clarified as incorrect, with the accurate calculation yielding a velocity of 70.7 m/s based on the provided parameters.
  • Understanding of Bernoulli's equation
  • Knowledge of fluid dynamics concepts
  • Familiarity with the formula for flow rate (Q = Area x velocity)
  • Basic geometry for calculating the area of a circle (Area = πr²)
  • Research the application of Bernoulli's equation in real-world fluid systems
  • Learn about the implications of velocity on pressure in fluid dynamics
  • Explore advanced fluid flow calculations using different pipe diameters
  • Study the effects of viscosity on flow rate and velocity
Engineers, physicists, and students studying fluid dynamics who need to understand the relationship between flow rate, pipe diameter, and velocity calculations.
grscott_2000
When using Bernoullis equation, part of it requires velocity to be input as part of it.
I am given flow rate of 5.00 m^3 per second. I am also told the diameter of a pipe that is 0.6 m. How do I calculate velocity?
I am assuming that velocity isn't simply 5.00 m/s
I know that flow rate (Q) = Area x velocity, therefore
velocity = Q / Area
I also know that Area is pi r^2,
thus I think that velocity = 5.00 / (pi * 0.15^2) = 70.7 m per second
Is this correct?
Many thanks for your time
Ok, I now know the formula for solving velocity from flow rate and pipe diameter.
If anyone is interested its
4 * flow rate / (pi * (pipe diameter)^2)
  • · Replies 16 ·
  • · Replies 30 ·
