How do i find the antiderivative of this
  • Thread starter Thread starter afcwestwarrior
    Antiderivative
The discussion revolves around finding the antiderivative of the function x/√(x² + 1). Participants are exploring methods of integration, particularly focusing on substitution techniques and the application of differentiation rules.
  • Participants discuss various approaches, including u-substitution and the application of the chain rule or quotient rule. There is some confusion about the appropriate methods for integration.
Some participants have offered guidance on using u-substitution, while others have questioned the correctness of initial attempts. There is an ongoing exploration of different interpretations and methods without a clear consensus on the correct approach.
One participant notes the importance of verifying results through differentiation, while another emphasizes the need to revisit foundational concepts in integration. There is mention of imposed homework rules that may limit the types of solutions discussed.
afcwestwarrior
x/ square root sign(x^2 + 1)
i did this x/ (x^2 + 1)^(1/2) simplified it
then i did this (x^2/2)/ 3/2(x^2 + 1)^(3/2) antidirevitionated it
then i cleaned it up x/ 3( x^2 + 1)^ 3
is this right
hmmm what did you do?
consider the u-substitution of
[tex]u=x^2[/tex]
so i have to use the chain rule or the quotient rule when i find the antiderivative of this
verify by differentiation that the formula x/square root (x^2 + 1) + C
is correct
this is what i have to do, but first i have to find the antiderivate of that function or polynomial, and then i have to just differentiate it which is easy
Let u = x^2 + 1
Then du = 2x*dx
So x*dx/(x^2 + 1)^(1/2) = du/(2*u^(1/2))
No, you should remember that there's no such thing as Chain rule, or Quotient Rule when finding an anti-derivative to one function.
You should re-read your textbook again carefully, and slowly to fully understand what you have to do. In integration, we can make a u-substitution, a trig-substitution, Integration by Parts, blah, blah, blah,... but not chain rule, or quotient rule. They are just for differentiating.
What you have done in your first post is not correct.
[tex]\int \frac{f(x)}{g(x)} dx \neq \frac{\int f(x) dx}{\int g(x) dx}[/tex], they are not the same.
I'll give you an example, similar to the problem. But you really should read your textbook first.
Example 1:
[tex]\int x \sqrt{x ^ 2 + 3} dx[/tex]
You should notice the x in front of the square root, it differs from the derivative of (x2 + 3, i.e, the expression inside the square root) by a factor 2.
[tex]\int x \sqrt{x ^ 2 + 3} dx = \int \sqrt{x ^ 2 + 3} x dx[/tex]
Let [tex]u = x ^ 2 + 3 \Rightarrow du = (x ^ 2 + 3)'_x dx = 2x dx \Rightarrow x dx = \frac{du}{2}[/tex]
The integral becomes:
[tex]... = \int \sqrt{u} \frac{du}{2} = \frac{1}{2} \int \sqrt{u} du = \frac{1}{2} \int u ^ {\frac{1}{2}} du = \frac{1}{2} \times \frac{u ^ {\frac{3}{2}}}{\frac{3}{2}} + C[/tex]
[tex]= \frac{1}{3} u ^ {\frac{3}{2}} + C = \frac{1}{3} \sqrt{u ^ 3} + C[/tex], now, change u back to x, we have:
[tex]... = \frac{1}{3} \sqrt{(x ^ 2 + 3) ^ 3} + C[/tex]
Example 2:
[tex]\int x e ^ {3x ^ 2 + 5} dx[/tex]
It's pretty similar to the previous one, let [tex]u = 3x ^ 2 + 5 \Rightarrow du = 6x dx \Rightarrow x dx = \frac{du}{6}[/tex]
[tex]\int e ^ u \frac{du}{6} = \frac{1}{6} \int e ^ u du = \frac{1}{6} e ^ u + C = \frac{1}{6} e ^ {3x ^ 2 + 5} + C[/tex]
Now, you can just do the same to your problem. Can you go from here? :)
