What is the key to solving an unbalanced Wheatstone bridge with a current value?
The discussion revolves around solving an unbalanced Wheatstone bridge circuit with a given current value. Participants explore various methods and approaches to determine the unknown resistance in the circuit, which includes a 40-volt battery, known resistors, and an ammeter indicating a current of 3 mA.
  • One participant describes the circuit configuration and expresses confusion about how to approach the problem, noting difficulties with Kirchhoff's rules and assumptions about voltage across the ammeter.
  • Another participant suggests that the entire 3 mA current might pass through the 5 kΩ resistor, implying a voltage difference between junctions based on this current flow.
  • A participant proposes a resistance value of 3.22 kΩ without elaboration on the reasoning behind it.
  • There is uncertainty regarding the direction of current flow in the circuit, with participants questioning whether current from the 9 kΩ resistor should be considered.
  • One participant mentions that the problem can be solved using Kirchhoff's rules by labeling currents in each branch and forming a system of equations, noting that the voltage across the ammeter is zero.
  • Another participant clarifies that there are four nodes and six branches in the circuit, challenging the initial understanding of branch points and nodes.
  • A participant recalls that the key to solving the Wheatstone bridge involves recognizing it as a combination of series and parallel circuits, suggesting a method to find the potential difference in the middle.
Participants express differing views on the application of Kirchhoff's rules, the identification of nodes and branches, and the direction of current flow. The discussion remains unresolved with multiple competing approaches and interpretations presented.
Participants demonstrate varying levels of understanding regarding circuit analysis terminology, such as nodes and branch points, which may affect their approaches to solving the problem. There is also a lack of consensus on the correct method to apply in this specific unbalanced scenario.
wjf0
We have been doing a lot of work with wheatstone bridges in class lately and our teacher gave us a problem to try and I'm totally lost. The diagram that we were given has a 40 volt battery hooked to a wheatstone bridge circuit. The positive power flows into two resistors, one is 9 kiloohms and its opposite is unknown. The 9 kiloohm side then goes to a 5 kiloohm resistor and the unknown flows into a 12 after which the two sides rejoin and return to the 40 V battery. There is an ammeter across the bridge showing a current of 3 mA and we are asked to find the unknown resistance.
I've been working on this for about two hours and have come up with a lot of ideas that just don't work out. First I tried using kirchhof's rules but found that I had not voltage across the ammeter part of the bridge, so I tried assuming zero volts and came up short. Using my matrix math I came up with nothing.
I also tried solving the bridge as though it was balanced and figured out the overall total current and tried to use the 3 mA given to try and figure out what the four currents would be when its not balanced.
All the work we have done in class so far has been with balanced bridges or with a voltage across the bridge. This is the first time we have seen an unbalanced bridge with a current value. I'm totally lost and any push in the right direction would be great. Thanks for taking the time to read about my problem.
Science news on Phys.org
wjf0,
Welcome to PF !
Do you have a preferred method for dealing with this circuit?
Is the 3mA flowing from the unknown side to the junction of the 9k and 5k resistors? ...and if so;
Have you considered that the entire 3mA would be passing through the 5k resistor? Do you think this might mean the junction on the right hand side must be 15 volts higher than the one on the left, regardless of whatever the actual values might be?
3.22 K?
Thanks for your response. One the diagram that we were given, we were not told the direction of the current. I had thought about what you said before, but I found myself wondering if there was any current coming from the 9K resistor that needed to be taken into account. As for a preferred method, I really don't have any because at this point I'm simply looking for any new ideas.
Are you certain there was not so much as a circle with and arrow inside (denoting a current flow and the direction thereof)?
Yes, you are correct. It is being fed by two paths. My hint was only to show what the current from one of the paths would mean.
You can't break down this circuit into a simple parallel or series diagram but there is more than one way to work it. I'm pressed for time today but will try to walk you through it later in the day if I'm able...assuming someone else doesn't beat me to it.
Good luck
WJ, this prob is solvable using Kirchoff rules (Sum(I)=0 in any junction , and Sum(V)=0 around any closed loop). Label currents in each branch (and you have 6 branches), get system of 7 equations and it is not hard to solve. Note that voltage on ammeter is zero. Don't worry about actual current directions - in your answers some of them will have negative sign if you labeled directions opposite, no big deal.
Alexander,
I tried to use kirchhof's rules, but I only see four branch points (the four corners of the wheatstone bridge). Where are you getting the other 2 from? Using the four branch points I developed four equations to solve for the four unknown currents in the resistors. I assumed zero volts in the ammeter and used matrix algebra to simultaneously solve the equations. All the calculator gave me was three equations in terms of the current going through the unknown resistor and there was no way to simplify it down to get the unknown current.
You have 4 nodes and 6 branches (4 sides of bridge and 2 diagonals).
We were taught in class that a branch point occurs where three conductors intersect. This only happens at four points on the diagram we are given. What do you mean by a node, we've never discussed them and I don't see what you mean when I look at the diagram.
Node = junction of branches (where current splits). Branch = elements connected in series from one node to another (same current via all elements).
It has been a long time since I messed with the wheatstone bridge. I do remember though that the key that helped me was to realize that it is a combination series parallel circuit. You have to break both down and then recombine them to find the difference of potential in the middle.
http://www.broadcast.net/hallikainen/theory6.html
17K
  • · Replies 25 ·
  • · Replies 30 ·
