Does Convergence in C^oo Guarantee Convergence in All C^k Spaces?
  • Context: Graduate
  • Thread starter Thread starter e12514
The discussion centers on the relationship between convergence in the space of infinitely differentiable functions, C^∞([0,1]), and convergence in the Banach spaces C^k([0,1]) for all k. It is established that if a sequence (f_n) is Cauchy in C^∞, then it is also Cauchy in C^k for all k, due to the properties of the metric d(f,g) defined as the sum of weighted norms. Furthermore, if (f_n) converges in C^∞, it converges in C^k for all k, as the convergence in C^∞ implies that the norms ||f_n - f||_C^i approach zero for all i. The discussion emphasizes the necessity of ensuring that the sequence remains Cauchy across all k without losing bounds on N_k.
  • Understanding of Cauchy sequences in metric spaces.
  • Familiarity with the properties of Banach spaces.
  • Knowledge of the space of infinitely differentiable functions, C^∞.
  • Comprehension of the metric d(f,g) involving weighted norms.
  • Study the properties of Cauchy sequences in Banach spaces.
  • Learn about the implications of convergence in C^∞ on C^k spaces.
  • Explore the construction and properties of the metric d(f,g) in functional analysis.
  • Investigate the completeness of C^∞ and its implications for convergence.
Mathematicians, particularly those specializing in functional analysis, graduate students studying advanced calculus, and researchers exploring the properties of differentiable functions and their convergence behaviors.
e12514
I have a cauchy sequence (f_n) in the space of functions on [0,1] which are infinitely differentiable, C^oo ([0,1]) = INTERSECTION C^k ([0,1]), k from 0 to oo, with the metric d(f,g) = SUM 2^-i * ||f-g||_C^i / ( 1 + ||f-g||_C^i ), i from 0 to oo
If we assume that we do not know whether ( C^oo, d ) is complete or not from the beginning, but that we know ( C^k, ||.|| ) are Banach spaces for all k,
is it valid to claim that (f_n) is cauchy in C^k ([0,1]) for all k?
reason:
(f_n) cauchy in C^oo
for all epsilon > 0 there exists N(depending on epsilon) in the set of natural numbers such that
m,n >= N => d(f_m, f_n) < epsilon
so there exists N s.t.
epsilon > d(f_m, f_n) = SUM 2^-i * ||f_m - f_n||_C^i / ( 1 + ||f_m - f_n||_C^i ), i from 0 to oo
i.e.
epsilon > SUM 2^-i * [ 1 / ( 1 + ||f_m - f_n||_C^i ) - 1 ] , i from 0 to oo
and so we can make the above sum as arbitrarily small as we desire,
therefore we can make ||f_m - f_n||_C^i as arbitrarily small as we desire since this is the only "variable" in the above sum.
i.e. ||f_m - f_n||_C^i < epsilon_i for all i
and hence (f_n) is cauchy in C^k for all k
Also with the same situation as before but this time I have a convergent sequence in C^oo, i.e. (f_n) -> f in C^oo
Is it valid to claim that (f_n) is convergent in C^k for all k?
reason:
with exactly the same method as before except replace "f_m, f_n" by "f_n and f"
or
(f_n) -> f in C^oo means
f_n - f -> 0, i.e.
d(f_n, f) -> 0, i.e.
SUM 2^-i * ||f_n - f||_C^i / ( 1 + ||f_n - f||_C^i ), i from 0 to oo, goes to zero, i.e.
||f_n - f||_C^i -> 0 for all i since 2^-i > 0 so the other part of the numerator needs to be zero
i.e. (f_n) -> f in C^k for all k
I'm not sure. I think you might have a problem with the N_k s, i.e. how far you have to go in the sequence before all terms are within epsilon of each other. If the N_k 's kept getting larger and larger, I'm not sure if you could say that f_n was cauchy in C^oo, because you might not be able to make that sum you mentioned as arbitraily small as possible. In other words, perhaps N_k needs an upper bound, or perhaps I'm simply being overly pedantic.
If for every k the sequence is cauchy, that means that the functions are converging to a limit in C^k. Perhaps if you found this limit and proved that all the C^k limits were the same?.
Actually, what if you could make all those terms in your sequence less than say epsilon*2^-k. Then the sum of the infinite geometric series would be less than epsilon. But woundn't you need an upper bound on N_k to do this.
I don't have any analysis texts in front of me. Sorry.
Okay, now I'm getting a bit confused...
I want to show that any sequence that is cauchy in C^oo implies it is cauchy in C^k for all k, and that any sequence that is convergent in C^oo implies it is convergent in C^k for all k.
So I can take any cauchy sequence in C^oo and can make that sum as small as desired, same with the second case where I can take any convergent sequence in C^oo...
