How Do You Calculate Alpha Particles' Impact and Behavior in a Current Problem?
  • Thread starter Thread starter xerox2ooo
    Physics
This discussion focuses on calculating the behavior of alpha particles in terms of current and resistance. The problem involves a steady beam of alpha particles with a charge of +2e, a kinetic energy of 20 MeV, and a current of 0.25 microamperes. Key calculations include determining the number of alpha particles striking a surface in 3 seconds, the number of particles in a 20 cm length of the beam, and the potential difference required to accelerate each particle to 20 MeV. The solutions utilize fundamental equations such as I = dq/dt and E = qV.
  • Understanding of electric current and charge (I = dq/dt)
  • Knowledge of energy and potential difference (E = qV)
  • Familiarity with the properties of alpha particles (mass and charge)
  • Basic kinematics to calculate velocity and time
  • Research the relationship between current and charge flow in electrical circuits
  • Study the kinetic energy of charged particles and its relation to potential difference
  • Learn about the mass and charge of alpha particles in nuclear physics
  • Explore kinematic equations for particle motion in physics
Students and professionals in physics, particularly those focusing on nuclear physics, electrical engineering, and particle dynamics, will benefit from this discussion.
xerox2ooo
Can anyone give some hints on this problem?
This is about current and resistance.
Problem: A steady beam of alpha particles (q= +2e) traveling with constant kinetic energy 20MeV carries a current of 0.25 micro ampere.
(a) If the beam is directed perpendicular to a plane surfece, how many alpha particlees strike the surface in 3.0s?
(b) At any instant, how many alpha particles are there in a given 20 cm length of the beam?
(c) Through what potential difference was it necessary to accelearte each alpha particle from rest to bring it to an energy of 20 MeV?
Thanks,
(a) Current is defined as the charge that flows through a cross section of the conductor in a given time frame:
[tex]I = \frac{dq}{dt}[/tex]
So to find the number of charges that go through the cross section (or in our case, hit the perpendicular surface), just rearrange that equation:
[tex]dq = Idt = 0.25\mu A3s[/tex]
Remember that each particle carries a charge of +2e so you need to divide the result by two to get the number of particles.
(c) The fact that the particles have 20 MeV of energy indicates the amount of energy that has gone into accelerating them. The energy that is given to a particle as it is accelerated by a potential difference is [tex]E = qV[/tex]. You have the energy, you have the charge of each particle, you can find the potential difference. :smile:
Gotta think a bit about (b), be right back...
Ok, for (b) you can find the velocity of the particles, right? You know their energy, and the mass of each alpha particle is 4 times the mass of a proton (it has two protons and two neutrons). Once you have the velocity of the particles, you can find how much time it would take on of them to cover a distance of 20cm:
[tex]\Delta t = \frac{x}{v}[/tex]
Now just plug that into the equation I used already above:
[tex]\Delta q = I\Delta t = I\frac{x}{v}[/tex]
(Again, divide the result by two to get the number of particles)
10K
