Is There a Method for Integrating Sinx/x Between 0 and Infinity?
  • Context: Undergrad
  • Thread starter Thread starter heidernetk
    Integral
The discussion centers around the integration of the function sin(x)/x from 0 to infinity, exploring various methods and approaches to solve the integral. Participants discuss numerical approximations, analytical techniques, and the challenges associated with the integral's non-elementary nature.
  • Some participants note that sin(x)/x does not have an elementary primitive function and suggest numerical methods for approximation, with one participant reporting a result of approximately 1.571.
  • Others mention that the integral is known to equal π/2 and can be proved using complex analysis or Fourier analysis, although the exact methods are not detailed.
  • One participant proposes using contour integration and residue theory, suggesting a method involving the integral of e^(iz)/z and finding the imaginary part.
  • Another participant describes a contour integration approach involving a semicircle in the complex plane and partitioning the contour into linear and circular components as R tends to infinity.
  • One participant questions the possibility of using integration by parts, while another asserts that it is not feasible and mentions the existence of the non-elementary Si(x) function as the antiderivative.
Participants generally agree that sin(x)/x does not have an elementary primitive function and that numerical methods can provide approximations. However, there is no consensus on the best method for solving the integral, with multiple competing views on the use of complex analysis, contour integration, and the limitations of integration by parts.
Participants express uncertainty regarding the steps involved in contour integration and the application of residue theory, indicating that some may lack recent experience with these techniques. Additionally, the discussion highlights the challenges posed by the singularity at the origin and the complexities of integrating over infinite limits.
This discussion may be useful for students and practitioners interested in advanced integration techniques, particularly those involving complex analysis and numerical methods for evaluating improper integrals.
heidernetk
Can you help me by giving me a method or solution
integrating sinx/x between (0,infinty)
please help me
sinx/x does not have the elementary primitive function. You can calculate it numerically by a program. I used Matlab and calculated it as :1.571
That's an approximation to [itex]\pi / 2[/itex]. Actually, the result
[tex]\int_0^\infty \frac{\sin x}{x} \: dx = \frac{\pi}{2}[/tex]
is somewhat well-known. It can be proved using complex analysis or Fourier analysis. heidernetk, do you have experience with either?
(I also seem to recall seeing another way of doing this that doesn't use complex/Fourier analysis, but I can't remember how the argument went.)
Using contour integration you can solve this. The trick is to use
[tex]\int\frac{e^{iz}}{z} \: dz[/tex] and find the imaginary part. This can be done using residue theory. However, I took that course long ago and don't know all the steps.
If i recall you can take the integral over a quarter circle with a radius of R in the complex plane and Quadrant I. Then look at the over all path compared to the path partitioned into linear components an the circular component as R tends to infinity.
There wouldn't be much point in asking the question for a maths homework/question sheet if the answer was "Done by computer". For integrals such as sinx/x, particularly when the limits involve infinity, complex analysis is often the way to go.
For the benefit of the original poster mostly :
1. Make the contour the semicircle through the upper half plane but with a slight bump around the origin due to singularity (due to cos part of e^iz)
2. Split the contour into 4 parts, from epsilon to R along the Real axis, the semicircle arc of radius R round to -R on the Real axis, from -R to -epsilon and then a semicircle from -epsilon to +epsilon. Doesn't matter which side of the origin that little contour goes, the orientated nature of the path sorts out the signs and residue contributions.
3. Use the residue theorem to relate this contour integral to the sum of residues within the contour.
4. Take R->infinity and use Jordan's Lemma to justify it giving zero contribution. By the fact the imaginary part of e^iz/z is even, you end up having the integrals from -infinity to -epsilon being equal to +epsilon to +infinity.
5. Thus means you just have to compute the little contour and the residue at zero. Stick it in the equation due to the Residue Theorem, rearrange and all going well and a following wind, you should get the answer.
On the scale of things, one of the much nicer contour integrals one ever does. I used to freakin' hate ones involving branch cuts from say -1 to +1.
Is there any way to solve this using integration by parts.
No there isn't and this is really pointless but the anti derivative is defined to be the non elementary Si(x) function.
  • · Replies 31 ·
