The Taylor series expansion for sin about z_0 = (pi/2)
The discussion focuses on expanding the cosine function into a Taylor series about the point z_0 = π/2 using the identity cos(z) = -sin(z - π/2). The Taylor series for sin is provided as sinu = ∑_{n=0}^{∞} (-1)^n * (u^{2n+1})/(2n+1)!. The correct approach involves substituting u = z - π/2 into the series for sin, resulting in the series for -sin(z) after applying the negative sign. The final expansion is expressed as - (z - π/2) + (1/3!)(z - π/2)^3 + ... + ((-1)^{n+1}/(2n+1)!)(z - π/2)^{2n+1}.
  • Understanding of Taylor series expansion
  • Familiarity with trigonometric identities
  • Knowledge of calculus, specifically derivatives
  • Ability to manipulate series and summations
  • Study the Taylor series expansion for other trigonometric functions
  • Learn about convergence criteria for Taylor series
  • Explore the application of Taylor series in solving differential equations
  • Investigate the relationship between Taylor series and Fourier series
Students studying calculus, mathematicians working with series expansions, and educators teaching trigonometric identities and Taylor series concepts.
laura_a
Expand cos z into a Taylor series about the point z_0 = (pi)/2
With the aid of the identity
cos(z) = -sin(z - pi/2)
sinu = \sum^{infty}_{n=0} (-1)^n * \frac{u^{2n+1}}{(2n+1)!}
and the identity as given above
I've subbed in -sin(z- pi/2) into the identity my first prob was how to deal with the negative in front of the sin so I've done
u = z-pi/2
-sin(z-(pi/2)) = -(z-(pi/2)) + 1/3! * (z-(pi/2))^3 - 1/5! * (z-(pi/2))^5
So if that is even correct (because I'm not sure about where to put the negative signs... then what does it mean when it says "about the point" z_0 = (pi/2)
How do I sub that into my answer?
Any suggestions will be much appreciated
Thanks
The Taylor's series of a function 'about' [itex]z_0= \pi/2[/itex] is the series
[tex]\sum_{n=0}^\infty \frac{d^n f}{d x^n}(\pi/2)(z- \pi/2)^n[/tex].
That is, you have powers of [itex]z- \pi/2[/itex] as well as evaluating the derivatives at [itex]\pi/2[/itex]. One method of determining the derivative is to use that definition directly: all derivatives of cos(x) are cos(x), sin(x), -cos(x), -sin(x) and those have values of 0, 1, and -1 at [itex]\pi/2[/itex].
However, you are completely correct that [itex]cos(z)= -sin(z-\pi/2)[/itex]. That means all you need to do is write the Taylor's series for sin(z), which is
[tex]z- (1/3!)z^3+ \cdot\cdot\cdot+ ((-1)^n/(2n+1)!)z^{2n+1}+\cdot\cdot\dot[/tex]
Multiply by -1 to get -sin(z):
[tex]-z+ (1/3!)z^3+ \cdot\cdot\cdot+ ((-1)^{n+1}/(2n+1)!)z^{2n+1}+\cdot\cdot\dot[/tex]
and finally replace z by [itex]z-\pi/2[/itex]:
[tex]-(z-\pi/2)+ (1/3!)(z-\pi/2)^3+\cdot\cdot\cdot+ ((-1)^{n+1}/(2n+1)!)(z- \pi/2)^{2n+1}+\cdot\cdot\cdot[/tex]
