Find Total Magnetic Flux Through a Wire and Loop
The discussion focuses on calculating the total magnetic flux through a square loop with resistance R, positioned a distance a from an infinitely long wire carrying current I. The magnetic field generated by the wire is given by the formula B = μ₀I/(2πa). Participants clarify that integration is necessary to account for the entire area of the loop, particularly when considering the contributions from different segments of the loop. The conclusion emphasizes the importance of evaluating the integral ∫B·dA over the loop's area to determine the total magnetic flux accurately.
  • Understanding of magnetic fields generated by current-carrying wires
  • Familiarity with the Biot-Savart Law
  • Knowledge of vector calculus, specifically line and surface integrals
  • Basic principles of electromagnetism, including magnetic flux
  • Study the Biot-Savart Law for calculating magnetic fields from current distributions
  • Learn about the integration of vector fields over surfaces in electromagnetism
  • Explore the concept of magnetic flux and its applications in Faraday's Law
  • Investigate the effects of wire orientation on magnetic field interactions with loops
Physics students, electrical engineers, and anyone interested in understanding magnetic fields and their effects on conductive loops in electromagnetic systems.
azone
a) There is an infinitely long wire carrying a current I. There is a square loop with resistance R a distance a from the wire in the same plane. Find the total magnetic flux through the loop.
b) There is an infinitely long wire carrying a current I in the z-direction. There is a square loop with resistance R a distance a from the wire in the xy plane. Find the total magnetic flux through the loop.
a) I know that the magnetic field from a straight wire is B=muo*I/2*pi*a. But isn't this just for a point a distance a away? What if it's a short line like the side of the loop? Does that mean I have to integrate? And also I know that there is no force on the two sides of the loop that is perpendicular to the wire, so does that mean that there is no magnetic field and hence no flux? So right now I guess I have a total magnetic field of B=mu*I/2*pi*a + mu*I/4*pi*a. And then I can find the flux from there.
b) I'm not sure at all how this wire affects the loop since they're not in the same plane. Does that mean there is no force on the loop at all? Or do I have to do some integration?
Notice that the question is asking for the magnetic flux through the loop. You'll need to evaluate [tex]\int \vec{B} \cdot d \vec{A}[/tex] over the area enclosed by the loop.
No. How did you come to this conclusion?
Do the same integration. What direction is the magnetic field due to the wire? What direction is the area vector? So, what can you say about [tex]\vec{B} \cdot d\vec{A}[/tex]?
