Finding V in a Simple Differential Equation for Concentric Spherical Conductors
The discussion revolves around finding the potential V in a differential equation related to concentric spherical conductors with given radii and potentials. The problem involves understanding the relationship between the potential and the distance from the center of the conductors.
  • Participants explore the separation of variables in the differential equation and question the interpretation of constants involved in the integration process. There is discussion about the correct form of the equation and how to approach the integration.
The discussion is active, with participants providing guidance on how to manipulate the equation and integrate it. There is acknowledgment of confusion regarding the constants and the separation of variables, indicating a collaborative effort to clarify the mathematical steps involved.
Participants are navigating through potential misunderstandings in the setup of the differential equation and the implications of the constants involved. The original poster expresses difficulty in starting the problem, highlighting the challenges faced in the initial stages of solving the equation.
John O' Meara
Two concentric spherical conductors radii a and b are at potentials V1 and 0 respectively. The potential V at a distance x from their common centre is given by [tex]\frac{d[x^2\frac{dV}{dx}]}{dx}=0 \\[/tex]. Find V in terms of x, a, b and V1 ( Note V=V1 when x=a and V=0 when x=b).
I just find it difficult to get started on this, I seem not able to separate out the variables dV and x. Thanks for the help.
Well, if (as you've written it) the derivative is 0, then x^2V' would be constant. That is separable.
Do I write down x^2V' =0, then [tex]x^2 \int dV =0[/tex]
No, you write
[tex]x^2\frac{dV}{dx} = k(constant)[/tex]
EDIT: Bah, I screwed up somewhere in the latex. arunbg wrote the essential part anyway
Is that constant k not =0? I mean the [tex]d[x^2\frac{dV}{dx}}] = dx \times 0 = 0 \\[/tex] In other words where did you get the k. Anyway I have the following [tex]V=k\int \frac{1}{x^2}dx \\[/tex].
You can't separate the original equation like that. You have [tex]\frac{d}{dx}\left(x^2V'\right)=0[/tex]. Integrating both sides wrt x gives [tex]\int \frac{d}{dx}\left(x^2V'\right)dx=k \Rightarrow x^2V'=k[/tex]
Your next part is correct. Now integrate that.
Thanks cristo for your help.
  • · Replies 27 ·
  • · Replies 18 ·
  • · Replies 18 ·
