Energy = mass * c^2 where c=speed of light
  • Context: Undergrad
  • Thread starter Thread starter expscv
    Energy Light Mass
The discussion revolves around the relationship between energy and mass as expressed by the equation E = mc², particularly in the context of light and the implications of special relativity. Participants explore concepts such as the mass of light, the conversion of energy into mass, and the challenges of accelerating objects to the speed of light.
  • Some participants question whether light has mass or energy, with one suggesting that light does not have proper mass but may have inertial mass.
  • There is a discussion about the implications of trying to accelerate an object to the speed of light, with some asserting that energy input leads to an increase in mass, making further acceleration more difficult.
  • One participant describes the concept of mass dilation, noting that as an object's speed approaches the speed of light, its mass increases, requiring more energy for acceleration.
  • Another participant presents a thought experiment related to the relativity of simultaneity, illustrating how different observers perceive events differently based on their relative motion.
  • Some participants express confusion about how light can have momentum and energy without having mass, and how it behaves differently from massive objects when interacting with other media.
  • There are repeated requests for clarification on complex ideas, indicating that some statements may not be easily understood by all participants.
Participants do not reach a consensus on whether light has mass or energy, and there are competing views regarding the implications of mass-energy conversion and the behavior of objects approaching the speed of light. The discussion remains unresolved with multiple perspectives presented.
Participants express uncertainty regarding the definitions of mass in different contexts (proper mass vs. inertial mass) and the implications of special relativity on energy and mass conservation. There are limitations in the clarity of some statements, leading to requests for rephrasing and further explanation.
expscv
energy = mass * c^2 where c=speed of light.
every mass (build up with atoms) when trying to reach the speed of light
and the energy put in will converted to mass. so is it convey into the same mass? depends on atom reaction i guess. but for light it self. does it means light do not have a mass or any energy?
Science news on Phys.org
wait i should post this to somewhere else?
If you are suggesting that a little clump of iron atoms that number 10,439 in the rest frame appears to have 11,342 iron atoms in it to an observer whizzing by at some fraction of the speed of light, you are incorrect. But maybe that is not what you are saying?
Light does have energy, and momentum as well.
Could you re-express this in an understandable form. I really can only guess at the meaning of your words.
sorry i was in a rash
1.does light have a mass or energy?
2.since by the law conservation of mass/energy work on all object
how come it have nothing to do with light.
3. i was told that if a object trying to reach the speed of light is impossible
and nothing can go faster than light. because once you put energy in push the obejct that energy will converted into mass and therefore harder to push.
and more energy reqired so on. (is it true?)
4. the energy is converted into mass, what kinda mass is it?
related
qualitatively and quantitatively the consequence of special relativity in relation to:
– the relativity of simultaneity
– the equivalence between mass and energy
– length contraction
– time dilation
– mass dilation
The relativity of simultaneity
If two events in different places are judged by one observer to be simultaneous then they will not generally be judged to be simultaneous by another observer in a different reference frame in relative motion. In other words, whether or not two events are seen by you to be simultaneous depends upon where you are standing.
Try this thought experiment offered by Einstein:
A train is fitted with light operated doors. The light fitting is in the centre of the roof, and is operated by a train traveller standing in the middle of the floor. When the train is traveling at half the speed of light, the train traveller turns on the light. The light travels forwards and backwards with equal speed and reaches both doors at the same time. The doors then open, and the train traveller sees them opening simultaneously. An observer standing outside the train watches this happen, but sees the back door opening before the front. This is because the back door is advancing on the light waves coming from the light, while the front door is moving away from the light waves.
The equivalence between mass and energy
The rest mass of an object is equivalent to a certain quantity of energy. Mass can be converted into energy under extraordinary circumstances and, conversely, energy can be converted into mass. For example, part of the mass is converted into energy in nuclear fission reactions. When a particle and its anti-particle collide, the entire mass is converted into energy.
Einstein’s famous equation expresses the equivalence between energy, E and mass, m: E = mc2. The amount of energy given off in a nuclear transmutation is related by this equation to the amount of mass “lost”.
In Special Relativity, the Law of Conservation of Energy and the Law of Conservation of Mass have been replaced by the Law of Conservation of Mass-Energy.
Length contraction
The length of an object measured within its rest frame is called its proper length (Lo). Observers in different reference frames in relative motion will always measure the length (Lv) to be shorter.
The equation that expresses this is L(v)= L(o) * sqrt( 1- (v^2)/(c^2))
For example: A train that is measured to be 100 metres long when at rest, travels at 80% of the speed of light (0.8 c). A person inside the train will measure the length of the train to be 100 m. A person standing by the side of the track will observe the train to be just 60 metres long.
Time dilation
The time taken for an event to occur within its rest frame is called the proper time (to). Observers in different reference frames in relative motion will always judge the time taken (tv) to be longer.
The equation that expresses this is T(v)= T(o)/( sqrt( 1- (v^2)/(c^2)))
For example: A traveller on a train with a speed of 0.8 c, picks up and opens a newspaper. The event takes 1.0 second as measured by the train traveller. As observed by a person standing by the side of the track the event takes 1.7 seconds.
Mass dilation
Another consequence of the theory of Special Relativity is that the mass of a moving object increases as its velocity increases. This is the phenomenon of mass dilation. It is another expression of the mass-energy equivalence and is represented mathematically as:
M(v)= M(o)/( sqrt( 1- (v^2)/(c^2)))
where
m = relativistic mass of particle,
m0 = rest mass of particle,
v is the velocity of the particle relative to a stationary observer and
c = speed of light.
This effect is noticeable only at relativistic speeds. As an object is accelerated close to the speed of light its mass increases. The more massive it becomes, the more energy that has to be used to give it the same acceleration, making further accelerations more and more difficult. The energy that is put into attempted acceleration is instead converted into mass. The total energy of an object is then its kinetic energy plus the energy embodied in its mass.
To accelerate even the smallest body to the speed of light would require an infinite amount of energy, all the energy of the universe, plus a whole lot “more”. Thus material objects are limited to speeds less than the speed of light.
Light is always at a constant speed unless slowed by another object depending on the density, it has it's own momentum and energie. If it had a mass it would not be able to travel at a given speed, slow through a field, and exit at the speed it first entered. Although an object that has a momentum, once slowed by an object, needs a force to speed it up again, this is what confuses me the most about light. [?]
Proper mass? No.
Inertial (aka Relativistic) mass? Yes.
Yes. It's true that the faster a body goes the greater its inertial mass is.
Inertial mass.
Actually the term "convert" refers to the fact that the form of the energy has changed. The total is a constant, i.e. mass is conserved in nuclear fission etc.
I used to wrongly think that a mass accelerating to c. gained the mass as # of atoms.
Robert Compton who wrote the book Design Notes: G.O.D. says this incorrect. He used a cube to demontrate the idea visually.
For exmaple:
The energy content of mass is stacked like this:
photon mass
photon mass
rest mass
inertial mass
inertial mass
As an mass accelerates on part the stack is converted to another. The total energy of the cube remains constant.
umm interesting i was thinking is possible for people to recyle energy
but the use of conservation energy/mass
1. it has no mass, a Photon has seen to have no mass, it obviously has energy, solar-cells. But think about this. Gravity only effects things with mass, black holes are just huge gravity wells, but light with no mass is pulled into black holes. Why? Particle-wave duality explains it.
2. I have no idea how it is breaking that law. maybe you could explain that, unless it was after the einstein thing, never read past there.
3. Nothing with mass is capable to move at the speed of light even. It really doesn't mean mass is generated, and appears with. But rather the effects of mass become in existent, which is why light is effected by gravity. Then the next problem, even if humans moved at the speed of about 0.7xc almost the speed of light, time is the same for them, but for earth, time would be extremely fast relative to the craft that moves that fast. move at 0.7xc for around 12 seconds i believe it was and 450 years go by for earth. Would you sacrific your life to be someone whom has moved the fastest?
No. The acceleration due to gravity, even in the Newtonian theory, does not vary with the mass of a test particle. General relativity treats the situation even more clearly: spacetime is itself distorted by the presence of mass, and everything, including massless particles, is affected by the distortion. Quantum-mechanical effects have nothing to do with it, since classical general relativity is not a quantum theory!
- Warren
i knew someone would say that one, i personally haven't got to that yet in school, so i can't explain that. What you said is basically all i know about that.
awesome light is everywhere but so hard to explain wat it is. for me ...
Sometimes the simplest things turn out to be the hardest to fully explain. Believe it or not, gravity is even more difficult to explain than light. No one fully understands gravity right now.
That's what keeps physics so exciting for me, personally. :)
- Warren
me to, the quest to understand, is very exciting, but i rather perfer theory of things we can never do type things. Theory of everything, nature of time, and others along those lines.
When one is discussing whether light has mass or not then one should be state whether they're speaking of proper mass or inertial mass (aka relativistic mass.) Gravity acts on all things which has passive gravitational mass. Since passive gravitational mass equals inertial mass and since light has inertial mass it is attracted by gravity.
Recall the Feynman Lectures Vol -I page 7-11 on this. See the Section entitled Gravitation and Relativity
One feature of this new law is quite easy to understand is this: In Einstein relativity theory, anything which has energy has mass -- mass in the sense that it is attracted gravitationaly. Even light, which has energy, has a "mass". When a light beam, which has energy in it, comes past the sun there is attraction on it by the sun.
The (coordinate/spatial) acceleration due to gravity is not a function of the proper mass of the particle it is a function of the particle's velocity. This was not true in Newtonian theory but it is in Einstein's theory.
That is merely describing the phenomena in terms of differential geometry. This is made possible by the fact that inertial mass is proportional to passive gravitational mass. Einstein then took these facts and phrased them in terms of differential geometry. It is not an explanation of the facts. It is a description of them.
The presence of spacetime curvature merely indicates the presence of tidal forces. However there can be a gravitational force (which is an inertial force) on a particle even when the spacetime is flat. All this means is that there are gravitational forces and no tidal forces
Einstein wrote on this concept of light having mass since it has energy. In his and Infeld’s book The Evolution of Physics dated 1938, Einstein comments on the observation made by an observer inside an accelerating elevator. The elevator observer claims that light is ‘weightless’. Einstein then explains on page 231
But there is, fortunately, a grave fault in the reasoning of the inside observer, which saves our previous conclusion. He said: “A beam of light is weightless and, therefore, it will not be affected by the gravitational field.” This cannot be right! A beam of light carries energy and energy has mass.
i was talking about rest mass, not inertial which i thought i had implied, i forgot the name. like in my #3 i sort of went over inertial. did i not?
If you're trying to explain the physics to someone on this point then its best not to imply this point but to make it precisely clear. My comment on this point was merely a suggestion. Ignore it if you disagree with it. But in my experience its best to state this explicity in discussions such as this. When explaining relativity to someone it's customary to qualify what you mean on this point at least once. By "customary" I mean that almost all authors of relativity texts (E.g. Wald, Ohanian, Schutz etc.) qualify what they mean by "mass".
well where I usually talk about physics, Its unneccessary to explain beyond implications
What is necessary depends on the person whom you're addressing.
I explained to the expscv that light has zero proper mass and non-zero relativistic mass. You then later told him "light has no mass" without qualifying it. From the question asked it appears as if expscv may not be aware of these different terms and different definitions. For all expscv knew, you might have been disagreeing with my statement that light has non-zero relativsitic mass.
I understand that you might think I'm being nitpicky. I don't wish to. But I recently ran into a poster in a newsgroup who thought that light has zero relativistic mass. So I don't make any assumptions regarding this point anymore.
yikes, i usually talk to people with a bachelors at least in physics, and sometimes there are people in like first year physics, (Grade 11?) asking questions like a first year university student, so usually even if others and myself, explain hardly. itll be alright, I am new here, i would like to know the general level explanation needed, so not nitpicking.
Not everyone here has a degree or has studied physics at the college level. And the person who claimed that the relativistic mass of light was zero claimed to have a BS in physics.
Its always a problem trying to figure out what level your answer should be when you don't know who the person is that you're posting to.
oh? do that matter? different answer for different peopel? i m doing year 12 right now
stuff i asked usually beyond my reqiument in school but as a interest i come here and learn more =)
bu the way anyone know wat that equation is in the banner of the forum (top of the page) thx
In some ways it does make a difference yes. For example: I shouldn't explain something in terms which are too simple for you since I run the risk of irritating you. However if I explain in terms you may not already know then its unhelpful.
For example: Proper mass is the magnitude of the 4-momentum 4-vector. If you didn't know what a 4-vector was then I just wasted your time.
Some people believe that when someone asks a question that they should post a precise and rigorous answer. You then see them posting all sorts of 4-vectors and tensors etc. If the person asking the question doesn't know what a 4-vector is then you've done nothing to help them. Many people don't like to post questions is that case since they don't want to come across as ignorant.
I would rather be helpfull above all else
oh ic...i think that if it is expline in a medium level term or higher would be better
cause if the person still don't get it, he/her could ask again. actually that would learned more. isnt?
Hard to say. I've never seen any firm rule on this apply. It seems to be a guessing game. For instance - Even for someone with a "medium level" understanding it is still uncertain what they know. It often depends on how they learned it and what question is being asked.
The quesion of the relativistic mass for light is a good example. If a student has a text which defines inertial (aka relativistic) mass, m, as
[tex]m = \frac{m}{\sqrt{1-v^2/c^2}}[/tex]
then they might think that the relativistic mass for light is undefined. They might think that its zero too. However if the students text defines inertial mass in the correct way, i.e. as m = p/v, then its obvious that anything with a finite momentum and finite speed has a finite m. This fact is not a well known fact but this is the most rigorous and the most precise way to define inertial mass and its the definition upon which all derivations of m are based. Its an unfortunate fact that basic physics texts don't explain this. However texts which are devoted to relativity often elxplain this.
Hence my suggestion to define precisely what one means by "mass" when speaking about whether or not light has mass or not.
I think mass is a measurement of movement.
I was kind of wondering about the same thing. if light has energy and photons have no mass, it doesn't really work out if you were to put it into E=mc^2
Photons is energy, electromagnetic, and therefore has no mass and travels in wave forms like light. So photons is a quantum of electromagnetic energy. So the equation should fit both ways... be it fusing 2 photons or something? Or putting photons into matter with mass.
  • · Replies 25 ·
  • · Replies 45 ·
  • · Replies 23 ·
