E-field due to a large circular plane of uniform distribution
The discussion focuses on calculating the electric field (E-field) due to a large circular disc with uniform charge density at a point located x meters away from its center. Participants emphasize the importance of integrating with respect to the radius (R) to determine the E-field accurately. An alternative method involving solid angles is mentioned, but the consensus is to prioritize the integration approach for clarity and accuracy. The distinction between calculating the E-field and the force on a charge is also highlighted, clarifying that the E-field must be determined first before calculating the force.
  • Understanding of electric fields and charge distributions
  • Familiarity with integration techniques in physics
  • Knowledge of solid angles in the context of electromagnetism
  • Basic principles of electrostatics
  • Study the derivation of the electric field due to a circular disc of radius R
  • Learn about the application of solid angles in calculating electric fields
  • Explore the relationship between electric fields and forces on point charges
  • Review integration techniques specific to electromagnetism problems
Students of physics, electrical engineers, and anyone interested in understanding electric fields generated by charge distributions.
iontail
E-field due to a large circular plane of uniform distribution!
Hi Imagine i have a circular disc of radius R with uniform charge density, and a small charge x meters away from its center. The idea is to calculate the e field for this charged disc on the small charge. I can solve this problem if i solve the problem by integrating with respect to r. But i was told this can also be done by using solid angles. Would some one please help me?
Hmm, what do you mean by solid angles? If you know the potential, you can get to the E-field.
Integrating is really the way to do it, and whatever way works for you (apparently integration) is a good way.
First of all, you mean the force on the charge (and not the field on the charge, which does not make sense). So you need to figure out the field at the location of the point charge and then multiply it by the magnitude of the charge to get the force.
Secondly, forget about the alternate method first and try to work out the field due to a circular disc of radius R at a point on the axis distant x units from the center. Can you do this?
(Do you have ideas for the solid angle method? If so, try it and post your solution here...)
