Nuclear Resonance: Effects of Width
  • Thread starter Thread starter 6Stang7
    Nuclear Resonance
The discussion revolves around the concept of nuclear resonance and its relationship to the width of the resonance, particularly focusing on how this width affects the rest energy and lifetime of the resonance. Participants are exploring the implications of width in the context of nuclear physics.
  • Participants are attempting to understand the meaning of "width" in nuclear resonance, with some relating it to the Heisenberg uncertainty principle and its implications for energy and time. Questions are raised about the meaning of "rest energy of a resonance" and whether it is a valid concept. There is also discussion about the relationship between lifetime, width, and the distance virtual particles can travel.
The discussion is ongoing, with various interpretations being explored. Some participants have offered insights into the nature of resonances and their characteristics, while others are seeking clearer explanations and connections between concepts. There is no explicit consensus yet, but the dialogue is productive in clarifying terms and relationships.
Participants are navigating the complexities of nuclear resonance and its terminology, with some expressing confusion over the definitions and implications of width, lifetime, and energy in this context. The original poster notes a lack of equations or clear definitions, which may be contributing to the uncertainty in the discussion.
6Stang7
The greater the width of the nuclear resonance,...
a) the greater the rest energy of the resonance
b) the greater the lifetime of the resonance
c) the lower the rest energy of the resonance
d) the shorter the lifetime of the resonance
e) nothing
Can't find any
I've looked all over the internet to try to find what is meant by width for nuclear resonance. The only thing I have found is with T2, where a larger T2=>sharp signal and T1=>broad signal, so from that, I assume the width of the wave, i.e. the wavelength. So a greater width means a greater wavelength which means the greater the lifetime of the resonance, so b. But this is purely a guess; I'd like to understand the physics here.
Heisenberg uncertainty relation.
If E is larger what must happen to t (time) ?
"rest energy of a resonance": could that even have a meaning ?
If the width, i.e the uncertainty of energy is greater, that implies that t, lifetime, is lower?
nuclear resonance - the resonance absorption of a gamma ray by a nucleus identical to the nucleus that emitted the gamma ray
resonance - an excited state of a stable particle causing a sharp maximum in the probability of absorption of electromagnetic radiation
I think d is correct.
But the most important think, I believe, is to be able to explain it clearly.
A clear explanation should start with a good description of what a resonance is.
'Resonance' is a terrible name for the phenomenon that's going on. What is actually happening is that the energies of the particles produced are varying due to the varying energy of the virtual particle interactions between them. Nuclear reactions occur due to i) the weak force ii) the strong force, both of which are communicated by virtual particles materialising from the vacuum a la Heisenberg. The longer duration they must exist for in order to travel the distance between the two interacting parent particles, the more tightly confined their spectrum of possible energies must be. Conversely, a virtual particle traveling a very short distance can have a (relatively) wide range of energies. The strong force interacts over a very, very short range, so generally their resonances are wider than interactions taking place through the weak force.
Ok, then a greater width would imply a shorter distance; however, I don't see how any of the answers relate to distance.
Think of lifetime. The smaller lifetime, the short distance the Virtual particle can travel.
But can you please tell us more about this resonance, there are several concepts in nuclear physics that uses terms as reconances.
What i mean in my first answer is that resnances are the "energy peaks" that a nuclues can absorb (compare to atomic spectrum). And the shorter the life time of a certain state/resonance, the more uncertainity in the energy (width of peak).
I talked with some fellow students, and the problem has been cleared up a little bit.
What is meant by width is the width of a peak in a probability function. I made this graph to help.
In this graph, P represents the probability of a particle being created, and E is the amount of energy that is placed in. the width that is in the question is the value W on the graph.
However, I am still lost here...
  • · Replies 0 ·
