How Do You Calculate tan2B if sinB = -5/13?
  • Context: Undergrad
  • Thread starter Thread starter Nik
    identities Trig
The discussion revolves around calculating the value of tan2B given that sinB = -5/13. Participants explore the relationships between trigonometric identities and the implications of the sine value on the cosine value and the tangent of double angles.
  • Homework-related
  • One participant outlines the initial approach to find tan2B using the identity tan2B = sin2B/cos2B and expresses difficulty in proceeding further.
  • Another participant suggests that there may be two possible answers based on the quadrant in which angle B lies, indicating that B could be in either the third or fourth quadrant.
  • A third participant provides specific values for tan2B as 120/119 and -120/119, indicating that these results are contingent on the chosen quadrant for angle B.
  • A fourth participant applies the Pythagorean identity to derive cos(B) from sin(B) and suggests substituting these values into the formula for tan(2B) to find the answer.
Participants do not reach a consensus on a single value for tan2B, as multiple values are proposed based on different assumptions about the quadrant of angle B.
The discussion highlights the dependence on the quadrant for determining the signs of trigonometric functions, which affects the final calculation of tan2B. There are also unresolved steps in the calculations presented by participants.
This discussion may be useful for students studying trigonometric identities, particularly in the context of homework or exams involving angle calculations and the properties of sine and cosine functions.
Nik
Hi, today I was writing my Identities final test and got stuck on one question which I couldn't solve.
The question was: If [tex]sinB=-\frac{5}{13}[/tex] find the exact value of [tex]tan2B[/tex].
I've got this far, correct me if I went wrong anywhere: [tex]tan2B=\frac{sin2B}{cos2B}=\frac{2sinBcosB}{2cos^2B-1}[/tex]
Then, when I tryied to solve further I came to a dead end, even though I tried many different ways.
Thanx in advance!
There should probably be 2 answers.
First of all, with that triangle, the hypotinuse is 13, x is +12 and -12, y is -5, and B is either in the third or fourth quadrant.
Fill in the equation using x as 12, then fill in the equation using -12.
Tnx for your help, the answers I've got are [tex]\frac{120}{119}[/tex] and [tex]\frac{-120}{119}[/tex]
Once I get my test back I'll post if the answers match.
If sin(B) = -5/13, then sin^2(B) = 25/169. Using the Pythagorean identity, we have that cos^2(B) = 1 - sin^2(B) = 1 - 25/169 = 144/169, which gives cos(B) = +/- 12/13. Plug those values into the formula for tan(2B) and voila...
  • · Replies 17 ·
  • · Replies 21 ·
