Calculate the molarity of the sulphuric acid.
  • Thread starter Thread starter Janka
    Acid Molarity
The discussion revolves around calculating the molarity of sulfuric acid in a neutralization reaction involving sodium hydroxide. Participants explore related calculations involving sodium metal and its reaction with water, as well as the stoichiometry of the reactions involved.
  • Homework-related
  • One participant requests help with calculations related to the reaction of sodium with water and the subsequent formation of sodium hydroxide.
  • Another participant asks for clarification on the definition of molarity and how to calculate it in the context of the reactions.
  • Some participants discuss the stoichiometry of the reactions, noting that 1 mole of sodium produces 1 mole of sodium hydroxide and 0.5 moles of hydrogen gas.
  • One participant calculates the molarity of sodium hydroxide formed from 0.011 moles of sodium, concluding it to be 0.055 mol/dm³.
  • Another participant provides calculations for the volume of hydrogen gas produced at room temperature and pressure, initially stating 123.75 cm³, later correcting it to 132 cm³.
  • Participants analyze the neutralization reaction, calculating the moles of sodium hydroxide used and relating it to the moles of sulfuric acid based on the balanced equation.
Participants generally agree on the stoichiometric relationships in the reactions, but there are variations in the calculations presented, and some participants express uncertainty about their previous answers.
Some calculations depend on assumptions about conditions such as room temperature and pressure, and there are unresolved discrepancies in the volume of hydrogen gas produced.
Students studying chemistry, particularly those focused on stoichiometry and acid-base reactions, may find this discussion beneficial.
Janka
Hello people...could u help me pls...coz i am rly stuck in these thing like calculations...i know all right answers but i am not too sure how to get them...please if somebody of us has a few minutes could u help me with that?
Thank you very much.
1.,
When 0.25 g of sodium metal was added to 200 cm3 ( an excess ) of water , the following reaction occurred.
Na(s) + H20 (l) --> NaOH ( aq ) + 1/2 H2 (g )
(i) calculate the number of moles of sodium taking part in the reaction.
Na = 23 g mol-1
0.25g / 23 g mol-1 = 0.011 mole
(ii) calculate the molarity of the sodium hydroxide solution which was
formed.
(iii) calculate the volume of hydrogen gas produced at r.t.p. (298 K and
100 kPa ). Assume that hydrogen is insoluble in water under these
conditions.
In another experiment 25.0 cm3 of 0.183 M sodium hydroxide were neutralised by 13.7 cm3 of sulphuric acid according to the following equation.
2NaOH (aq) + H2SO4 (aq) --> Na2SO4 (aq) + 2H2O ( l )
Again, please show your work.
oki doki...sorry i didn t know about this rule.
calculation...could somebody help me please?
1.,
Na = 23 g mol-1
formed.
conditions.
(ii) How many moles, relative to sodium, of sodium hydroxide are produced in the reaction?
What is the definition of molarity?
(iii) How many moles of hydrogen, relative to sodium, are produced? What equation might you use to convert this number of moles into a volume?
(other experiment) How many moles of NaOH are used in this neutralization? How does this number of moles of NaOH relate to the number of moles of H2SO4?
Janka, please read about balanced equation meaning. Especially 2nd paragraph on the page. Once you will master this information, stoichiometry should become obvious :)
hey janka...
hhmm... the first one is good...
molarity means how many moles of a substance is present in a definite volume. as you know it, we often use mol/dm3
here you have 200cm3 of water. the NaOH will be present in there. now, you only need to know how much of NaOH is in the 200cm3 water.
from the first equation, 1 mol of Na gives 1 mol of NaOH. but you are using 0.011 mol Na, so you will get 0.011 mol NaOH (by proportion).
then, it should be true that 200cm3 of solution (water + NaOH) contains 0.011 mol NaOH. therefore, in 1000cm3 solution, you will get (0.011*1000)/200 = 0.055 mol NaOH.
you have just calculated the molarity: 0.055 mol/dm3
using the same proportion method: from 1 mol Na you get 0.5 mol H2. But you are using 0.011 mol Na, so you'll get 0.0055 mol H2.
at stp, 1 mol of a gas occupies 22.5dm3
0.0055 mol H2 will occupy, 22.5*0.0055 = 123.75 cm3
from the other exp:
you can calculate the amt of NaOH that reaced.
1000cm3 contains 0.183 mol NaOH
25 cm3 will contain 0.005 (approx.) mol NaOH
according to the eqn, 2 mol NaOH reacts with 1 mol H2SO4
0.005 (using the true value) mol NaOH will react with 0.002 mol H2SO4
therefore, 13.7 cm3 of H2SO4 conatins approx. 0.002 mol
using the exact value, 1000cm3 H2SO4 will contain 0.17 mol = approx. 0.2 mol H2SO4
i'm getting the feeling tat i already replied to this question... nyway... it won;t kill anyone if i do it again...lool
i may b sooo stupid sometimes lool... I've already answered this question in the other thread...
eerrmmm... in this one I've made an error though...
it took stp instead of rtp...
so the volume of H2 would be 132 cm3 instead of 123.75 cm3
Hello Kushal
Hi Kushal,
thanks a lot for your help, i was doing this calculations again this year, it really helped me, Thank you !
13K
22K
