Specific Heat Capacity and Change in Internal Energy
The discussion revolves around two physics problems related to specific heat capacity and internal energy changes. The first problem involves a jar of tea cooling down after adding ice, while the second problem concerns the internal energy of a gas during a lifting process involving work and heat transfer.
  • Mixed
  • Participants explore energy transfer concepts, questioning how to account for the melted and remaining ice in the first problem. They discuss the energy released by the tea and how it relates to melting ice and warming it to a specific temperature.
  • In the second problem, participants consider the work done on the gas and the heat added, questioning how these factors influence the net change in internal energy and the final internal energy.
  • There is a suggestion to use both latent heat and specific heat equations to analyze the first problem, with questions about which equations are appropriate for different phases of the process.
The discussion is active, with participants raising relevant questions and exploring different aspects of the problems. Some guidance has been offered regarding the need to consider both latent heat and specific heat in the first problem, indicating a productive direction in the conversation.
Participants are working under the constraints of homework rules, which may limit the information they can use or the methods they can apply. There is an ongoing exploration of assumptions related to energy transfer and phase changes in the context of the problems presented.
nellydude88
I'm having trouble with the following two problems:
1. A jar of tea is placed in the sunlight until it reaches an equilibrium temperature of 32*C. In an attempt to cool the liquid, which has a mass of .180kg, .112 kg of ice at 0*C is added. At the time at which the temperature of the tea (and melted ice) is 15*C, determine the mass of the remaining ice in the jar. Assume the Specific heat capacity of the tea to be that of pure liquid water.
2. The heaviest snake ever found had a mass of 227 kg and measured 8.45 m in length. Suppose a sample of a gas with an initial internal energy of 42.0 kJ performs an amount of work equal to that needed to lift the snake to a height equal to its length. If 4.00 kJ of energy is transferred to the gas by heat during the lifting process, what will be the final internal energy of the gas?
1. C[p,t] * M [t] * (T[f]-T) = C[p,i] * M * (T[f]-T)
Specific Heat of Water = 4.186 x 10 ^ 3.
Specific Heat of Ice = 2.09 x 10 ^ 3
2. PE + KE + U = 0
PE = m*g*h
KE = .5m * V ^ 2
1. (4.186 * 10 ^3) (.180kg) (17) = (2.09 x 10 ^ 3)(.112kg)(15)
I am unaware of how to account for the melted and remaining ice.
Do i just do like a mass initial and final?
2. (227 kg) * (8.45 m) * (9.81) = 18, 817 J I really don't think I am anywhere close to the right answer.
Your help is greatly appreciated.
When the tea cools from its initial temperature to 15C, how much energy is released? How much ice can be melted and then warmed to 15C by that amount of energy?
The gas (a) does some work and (b) has heat flow into it. What's the net change in internal energy? What's the final internal energy?
Would i be using the latent heat equation to figure this out? Q = mL? And if so would i use the latent heat of water? or would i use the specific heat cpacity equation? C[p] = energy transferred as heat/ (mass* change in temperature)
You'll need to use both. The ice first needs to be melted (latent heat of fusion) and then the resulting water needs to be heated (specific heat of water).
You'll to set up an equation and solve for the unknown mass of ice that melts.
  • · Replies 17 ·
  • · Replies 16 ·
