Calculating the Mass of a Uniform Scaffold Pole with Attached Brackets
  • Thread starter Thread starter Firepanda
    Mechanics Moments
The discussion revolves around calculating the mass of a uniform scaffold pole that has brackets attached to it. The problem involves determining the center of mass of the system, which includes both the pole and the brackets, and is set within the context of mechanics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the concept of center of mass and how to apply it to the system of the pole and brackets. There are attempts to set up equations based on moments and discussions about the correct placement of the center of mass for a uniform pole.
The discussion is active with various participants attempting to clarify their understanding of the problem. Some have provided hints and suggestions for approaching the calculation, while others express confusion about the setup and the assumptions being made. There is no clear consensus on the correct method yet, as participants are still working through their reasoning.
There are indications of misunderstandings regarding the position of the center of mass of the pole and the reference points used in calculations. The original poster's attempts at using moments are questioned, and there is a suggestion to reconsider the uniform distribution of mass in the pole.
Firepanda
A uniform scaffold pole of length 5m has brackets bolted to it as shown in the diagram below. The mass of each bracket is 1kg.
http://img502.imageshack.us/my.php?image=mechanicseb9.png
The centre of mass is 2.44m from the left hand end. What is the mass of the pole?My attempt:
I tried using the equation
moment of whole mass at centre of mass = sum of moments of individual masses
where
x = mass of pole
whole mass = (8 + x)
moment of whole mass = 2.44
sum of moments = 17
so:
(8+x)*2.44 = 17
yet this is obviously wrong. The answer should be somewhere around 42kg.
Thx for any help :)
this is a simple Center of Mass problem I believe where you have to "reverse engineer" and find the mass of pole. So, think about how you would find the Center of Mass of the system IF you have known the mass of the pole (which I presume has uniform mass distribution).
hint: where is the center of mass of the pole alone if it has uniform mass distribution?
when you have several point masses how do you find the center of mass of this system of point masses?
well if i knew the mass of the pole i could put 42 in as x, which gives me a sum of the moments of the individual masses as 122. So did i get the sum of the moments wrong?
maybe if i think about it like this:
taking x to be the centre of mass and 42x to be the sum of the moment at the centre of mass of the pole
50x = 17 + 42x
x = 2.125
reversing this like you say:
taking x as mass of the pole again (and cntre of mass to be 2.44)
(8 + x)*2.44 = 17 + 2.44x
but this is obviously wrong again
i am really lost at why are you doing things like this...
there are basically 9 "point masses" distributed on a straight line! and your task is to find the center of mass of this system.
firstly, work out the location of the center of mass of the pole which is nothing but the mid-way point if mass distribution is uniform,
then consider the baskets as point masses so you have 9 points on a line.
next select a reference frame (ie. a coordinate system) so that you have an origin to relate distances...look at your formula for working out the center of mass of a system of particles... and then solve the equation for mass of pole...
am I missing something? this seems rather "easy"
you been saying "moments", moments about what? it is meaningless unless you have an origin or axes... I know where you get the 17 from.. but you should really be more precise on your language
and yes.. the answer is exactly 42Kg
could u show me how u did it please :) its from an excersise which uses moments in every question with the one formula i have, it works for every question for me apart from this one. mayb ur using a diferent formula which id love to know about :)
ok.. now I can see where you 've gone wrong... you made just one error.. the position of the center of mass the pole alone is not 2.44 from the left.. it should be at mid-point of the pole.
can u show me ur exact calculation? u don't have to explain it, ill see what i did wrong myself:)
this is very close... except on RHS it is not 2.44 but the distance from left to mid-point of pole (where the center of mass of the pole lies)...which is just...
5/2 :)
thankyou!
  • · Replies 0 ·
  • · Replies 16 ·
