Stoichiometry Help: NaHCO3 & CaCO3 Reactions
  • Thread starter Thread starter Mack
    Stoichiometry
This discussion focuses on the stoichiometric analysis of reactions involving sodium bicarbonate (NaHCO3) and calcium carbonate (CaCO3) when reacted with vinegar. Key data includes the mass of reactants, moles of CO2 produced, and the identification of limiting reactants. The balanced chemical equations for both reactions are essential for determining the theoretical yield of CO2. Participants are encouraged to consider experimental errors that may affect the results.
  • Understanding of stoichiometry and limiting reactants
  • Familiarity with balanced chemical equations
  • Knowledge of mole conversions and mass calculations
  • Basic laboratory techniques for accurate measurements
  • Study the balanced equations for NaHCO3 and CaCO3 reactions with acetic acid
  • Learn how to identify limiting reactants in chemical reactions
  • Research methods for calculating theoretical yields in stoichiometry
  • Explore common sources of experimental error in laboratory settings
Chemistry students, educators, and laboratory technicians seeking to enhance their understanding of stoichiometric calculations and reaction analysis.
Mack
Data Table
.........NaHCO3...CaCO3
1. Mass of micro plate.....2.05g....2.05g
2. Mass of micro plate +salt...3.05g...3.05g
3. Mass of Salt .....1g.....1g
4. Moles of salt.....1/84 mol...1/100 mol
5. Mass of unreacted setup...20.66g....17.9g
6. Mass of reacted setup.....20.58g...17.85g
7. Mass of CO2 lost......08g.....05g
8. Moles of CO2 lost.....0018mol...0011 mol
9. Mass of Co2 produced as % of mass of sample 8% 5%
(reacted with vinegar)
Questions:
1. Write balanced equation for each raction.
2. From the stoichiometric relationships in the data table, find the # of moles of CO2 actually produced by each reaction.
3. How did the number of moles of CO2 actually produced by each reaction compare with the number of moles that ideally should be produced?
I don’t get how to do numbers 2 and 3. I believe I did number 2 in 8 on the chart but then what is the ideall number of moles? That’s were I am confused please help :frown:
You will need to find out which reactant is limiting. Then you will need to have the balanced equation in front of you to help you with your molar ratios for the stoich. Once you have found out what substance is limiting you will know how much CO_2 is produced. Then all you need to do is convert the grams to moles and you are all set. For question #3 you need to think about experimental error. What could have gone wrong in the lab? Did you spill anything? Were your measurements accurate? Did you make sure to get all of the mass out of the reactor vessel before you took the mass on a balance? Think upon those lines.
Good Luck!
-Steve
  • · Replies 19 ·
11K
9K
11K
