Solving a Differential Equation for Bungee Jumping Motion
The discussion focuses on solving a differential equation related to bungee jumping motion, specifically using Newton's second law of motion. The jumper's position is represented by x(t), where the bungee cord length is L = 50m. The restoring force follows Hooke's Law, defined as 0 for x ≤ L and -k(x - L) for x > L, while air resistance is modeled as -c(dx/dt). Participants clarify that the equation of motion can be derived by combining these forces into Newton's equation, m(d²x/dt²) = F.
  • Understanding of Newton's second law of motion
  • Familiarity with Hooke's Law and its application
  • Knowledge of differential equations
  • Basic concepts of air resistance in physics
  • Study the derivation of differential equations from Newton's laws
  • Explore applications of Hooke's Law in real-world scenarios
  • Learn about modeling air resistance in motion equations
  • Investigate numerical methods for solving differential equations
Students studying physics, particularly those focused on mechanics and differential equations, as well as educators looking for practical examples of motion modeling.
OrisAble
Well as above I've completely hit a blank for some uni work I've got.
If anyone could give me an idea of what i actually need to do here that would be great. I don't need someone do this for me. Just clear up what it is they want me to do.
"...Bungee jumping situation
Choose x= x(t) (positive donwards) to represent the location of the jumper's feet below the launching platform. Assume the bungee cord is of length L = 50m. Hooke's Law is to be used to represent the restoring force when the cable is stretched beyond length L, that is
Restoring force =
{0 x<=L
{k(x-L) x > L
Assume further, that their is an air resistance term opposing the motion of magnitude
cx(with the dot on top)|x(with the dot on top)|
Use Newton's equation of motion to determine the DE that describes the motion at times t>=0."
Thats what i don't understand. What does that actually want?[/quote]
Newton's equation is "force= mass times acceleration" or, for constant mass,
[tex]m\frac{d^2x}{dt^2}= F[/tex]
Here you are told that F is the sum of two separate forces: the restoring force which is 0 for x< L and -k(x-L) for x>L (the "-" is because the force is back toward x= 0) and the air resistance force which is -c dx/dt (again negative because the air resistance is always opposite to the direction of motion). Put those together.
Would be great if anyone could give me some direction..btw, ill be replying with a different account as i had forgotten my password and can't check hotmail accounts at uni ;).
well i just found out my account was deleted. Just realized i signed up with the same name as i use to have. maybe some of you remember me...
Newton's law is "force equals mass times acceleration" or, for constant mass, m d2x/dt2= F. Here you are told that the force is the sum of two forces: the restoring force, 0 if x< L, -k(x-L) (negative since the force is back toward x=0) and the air resistance force -c dx/dt (again negative since resistance is always opposite the direction of motion). Put those together.
  • · Replies 0 ·
