Is There a Quick Formula for Calculating Perfect Numbers?
  • Context: Undergrad
  • Thread starter Thread starter harisma
    Formula
The discussion revolves around the search for a quick formula to calculate perfect numbers, exploring both proposed formulas and the relationship between perfect numbers and Mersenne primes. Participants engage in mathematical reasoning, theoretical exploration, and some challenges to the validity of the proposed formula.
  • One participant presents a formula for calculating perfect numbers, claiming it works for the first 15 perfect numbers but lacks the means to test it further.
  • Another participant discusses the relationship between perfect numbers and Mersenne primes, suggesting that determining the primality of Mersenne primes is crucial for finding perfect numbers.
  • Some participants explore the implications of Mersenne primes and their properties, noting that the list of such primes becomes sparser as numbers increase.
  • A later reply expresses skepticism about the proposed formula, stating it does not work for larger perfect numbers.
  • Further discussion reveals confusion regarding the nature of sequences of primes and their relation to perfect numbers, with some participants correcting earlier statements about arithmetic sequences.
  • One participant attempts to clarify the formula for better understanding, while another humorously requests a formula for calculating odd primes.
Participants do not reach a consensus on the validity of the proposed formula for calculating perfect numbers. There are competing views regarding the relationship between perfect numbers and Mersenne primes, and the discussion remains unresolved regarding the efficacy of the formula for larger perfect numbers.
Some participants express uncertainty about the generalization of the formula and its applicability to larger perfect numbers, highlighting limitations in testing and assumptions made about prime sequences.
harisma
Hi there:)
I found a quick formula for calculate perfect numbers.
T(v)={{[1+sqrt(1+8*T(v-1))]*[1+sqrt(1+8*T(k))]}^2}/128 - {[1+sqrt(1+8*T(v-1))]*[1+sqrt(1+8*T(k))]}/16
T(v-1) is the previous perfect number and T(k) is ONE of the previous, that is to say that k=(1 or 2 or ...or v)
This formula works fine for first 15 perfect numbers but i don't have the knowledge in computer's to test it in biggers perfects.
If the formula is right, then to find the 41 perfect number we have to check only 40 numbers!
If anyone has the knowledge in programing to test the formula that will be pretty good!
This matter is about 2^(n-1)(2^n-1). In this case 2^n-1 is a prime, to be exact, called a Mersenne prime, of which much research has been done.
To find the sum of the factors (1+2+4+++2^(n-1)(1+2^n-1) =(2^n)(2^2), which is twice the original number, (since the number itself is counted as a divisor.)
So that the matter is all about determining if 2^n-1 is a prime or not. That seems to be as easy a way to proceed as any.
Looking at what you are doing in more detail, I take it that if we go through all the math, we are really saying that if 2^K-1 is prime and 2^m-1 is also a Mersenne prime, then by adding exponents and subtracting 1 we find that 2^(p+k-1)-1 is also a Mersenne prime.
Looking at Mersenne primes for N=2,3,5,7,13,17, 19, 31, 67, 127, 257...Of course disregard N=2, but proceeding to 496 and 8128, for N=5 and N=7, we would expect N=11 to be the next case, but N=13 is the next case. However for N=7 and N=13, the case of N=19, works out. Just as it does for 28 and 496, where N=3+5-1 =7, giving us the case of 8128. (The easiest and most likely case to test.)
You will observe that the list above of M. primes gets thinner and thinner so that no two of them can add up to 257. Your idea would allow an arithmatic sequence of primes. Of course, no such thing is know.
Tao and Green: existence of arbitrary length arithmetic sequences of primes.
Oops! I guess it is known. But it could not fit this case using any of the perfect numbers, as indicated by harisma.
Hello again!
Its not exactly an arithmetic sequence of primes . Its not a sequence because formula gives and others numbers, that they I don’t have some interest. Is a better way to calculate perfect numbers (and Mersenne’s prime’s of course).
But to be sure for this, must someone test it in bigger perfects!
The formula is wrong :/ it's not working in bigger perfects:(
Thank you!
harisma: The formula is wrong :/ it's not working in bigger perfects.
I thought Mr. Harisma that I had explained that: Of course disregard N=2, but proceeding to 496 and 8128, for N=5 and N=7, we would expect N=11 to be the next case, but N=13 is the next case.
However, I did make the mistake of generalizing this from the standpoint of an arithmetical progression. But there is no way in which any of your cases could allow us to progress to p=257, because the sum of 67 + 127 -1= 193, which is not a Mersenne prime, that is: 2^(193)-1 is not prime. (You will observe that the list of M. primes gets thinner and thinner so that no two of them can add up to 257.)
[tex]T_v=\frac{{(1+\sqrt{1+8T_{v-1}})*(1+\sqrt{1+8T_{k}})}^2}{128} - \frac{(1+\sqrt{1+8T_{v-1}})*(1+\sqrt{1+8T_{k}})}{16}[/tex]
For the sake of making it easier to read, I think that's what you were trying to say^^
Can you give us a formula to calculate odd primes? :)
  • · Replies 20 ·
  • · Replies 38 ·
