Statistical analysis of photometric data - Astronomy
The discussion centers on converting Hipparcos data from magnitudes to flux for statistical analysis in astronomy. The conversion is necessary because magnitudes are logarithmic, which can distort the normal distribution when plotting frequency histograms. The standard apparent magnitude formula, m=-2.5log(F/Fo), is used to derive flux density, which provides a more accurate representation of light intensity. This approach ensures a reasonable spread of data up to ±5 standard deviations from the mean.
  • Understanding of Hipparcos data and its significance in astronomy
  • Familiarity with the concept of magnitudes and their logarithmic nature
  • Knowledge of statistical distributions, particularly normal distribution
  • Basic grasp of the apparent magnitude formula and its components
  • Study the conversion process from magnitudes to flux density in detail
  • Learn about statistical methods for analyzing astronomical data distributions
  • Explore the implications of using logarithmic scales in data representation
  • Investigate software tools for plotting frequency histograms in astronomical research
Astronomy students, data analysts in astrophysics, and researchers involved in photometric data analysis will benefit from this discussion.
big man
My class is doing an assignment where we have to create a programme to convert the Hipparcos data from magnitudes to flux so that it when you plot a frequency histogram of the data you will have an approximation of a normal distribution. I've completed this OK, but I was wondering why this is the case?
Why do you need to convert the data from magnitude to flux? Is it because magnitudes are logarithmic and so wouldn't get an accurate normal distribution with a reasonable spread up to +- 5 std from the mean?
That's all I can think of. Am I on the right chain of thought here? Any advice on this would be extremely helpful and appreciated.
Thanks
I think you're right in your reasoning, but maybe somebody else can offer further insights. In the mean time, at least this bumps the thread. So when you say flux, do you mean light intensity measured as the power per unit area arriving here (on Earth)?
In a strict sense it won't be the actual flux (in terms of its value), but it is still flux as per your definition. In fact I probably should have said flux density.
It is determined by rearranging the standard apparent magnitude formula of:
m=-2.5log(F/Fo)
11K
