Finding Speed of Space Shuttles & Submarines
  • Context: High School
  • Thread starter Thread starter Unreal
The discussion revolves around the methods for determining the speeds of space shuttles and submarines, exploring both theoretical calculations and practical considerations. It includes aspects of physics related to orbital mechanics and hydrodynamics, as well as technological implications.
  • One participant notes that the space shuttle requires a sufficient tangential velocity to maintain orbit, and provides a link to a resource for calculating orbital velocity at a given altitude.
  • Another participant discusses the speed of submarines, suggesting that their maximum speed is determined by the balance between engine output and hydrodynamic drag, and mentions the need for specific measurements to calculate this accurately.
  • A participant questions how technology enables submarines and shuttles to achieve their respective speeds, indicating a curiosity about the underlying mechanisms.
  • It is highlighted that speed is relative, particularly for submarines, which must account for both water speed and ground speed, influenced by ocean currents.
  • One participant explains that the speed of a rocket, such as the shuttle, is achieved through significant fuel consumption, emphasizing the ratio of fuel to payload during launch.
Participants express various viewpoints on the calculations and factors influencing the speeds of shuttles and submarines, indicating that there is no consensus on the specifics of how these speeds are achieved or measured.
Participants mention the complexity of accurately calculating speeds due to the need for detailed measurements and the influence of external factors like currents for submarines. There are also assumptions regarding the capabilities of submarine hulls and the physics of rocket launches that remain unaddressed.
This discussion may be of interest to those studying physics, engineering, or anyone curious about the mechanics of space travel and underwater navigation.
Unreal
How do you find...
Im wondering whether how you find the speed of
a) space shuttle
and
b) submarines?
Any answer will be appreciated :smile:
The space shuttle must have a large enough tangential velocity to keep it in orbit. The velocity of a satellite in a circular orbit at a known altitude can be easily calculated:
http://hyperphysics.phy-astr.gsu.edu/hbase/orbv3.html
The velocity of a submarine, however, is up for grabs. The submarine could, of course, just stop and sit still.
The maximum speed that a submarine can reach will be the point where its engine output (in horsepower, for example) equals its losses due to hydrodynamic friction (drag). This assumes, of course, that the submarine's hull is capable of handling that kind of drag and so on. If you know the frontal area and drag coefficient of the sub, plus its maximum engine output, the top speed is also easy to calculate. You could probably look up the drag coefficient for a hemispherical front-end, which I believe most subs have. These kinds of things are difficult to calculate accurately without a lot of very specific, detailed measurements.
http://hyperphysics.phy-astr.gsu.edu/hbase/airfri2.html#c2
- Warren
ok. I see...
If such speed is attainable, so how does technology achieve such speed? :confused:
It's also important to bear in mind that speed is always relative. This may not be terribly important for the shuttle, but it is a significant factor for the sub. Because a submarine travels through a fluid medium, much like aircraft, it has two important speeds to be calculated; water speed and ground speed. For example, if a submarine is traveling through a part of the ocean in which there is a prevailing current that moves eastward at approximately seven knots, and the sub shows a water speed of 30 knots with the heading of East, the sub is actually traveling eastward at a speed of 37 knots relative to the ocean floor, or the nearest landmass. Just like a crosswind can blow an airplane off course, currents in the water are significant factor that must be calculated when navigating a submarine.
I assume this:
Unreal said:
ok. I see...
is in reference to the shuttle speed. Truth is, this velocity is achieved through sheer brute force. When a rocket is sitting on the launch pad, something like 80-90% of its total weight is just fuel. So, for every one pound of spacecraft that makes it into orbit, eight or nine pounds of high explosive has been blown up underneath the payload to get it up there.
  • · Replies 33 ·
