Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Engineering > Electrical Engineering
Reply
image Maximum frequency of electrical pulses through wire? Share It Thread Tools Search this Thread image
Old Mar27-04, 10:40 AM                  #1
Matt Jacques
Matt Jacques is Offline:
We have Pentiums ranging in the mid three gigahertz range, they're not too efficient, but how do the electronics generate the clock pulses at such a high frequency? What I am asking is, what is the maximum frequency of pulses through an electrical wire? And How would someone say, produce a frequency of, say, a terahertz, or a petahertz in a wire?
Old Mar27-04, 11:43 AM                  #2
Janitor
Janitor is Offline:
Recognitions:
"Self inductance" is what you are asking about.
Even a straight wire has inductance, and it causes problems for circuit designers at high enough frequencies. I have seen various approximations to the high-frequency limit of self inductance. One such is:
L=0.002 l [ln(2 l/r) - 3/4]
for the inductance L in microHenries, where l is the length of the wire in cm and r is the radius of the wire in cm. (Careful: don't read "l" as "one" in the formula.)
Old Mar27-04, 01:28 PM       Last edited by Janus; Mar27-04 at 01:30 PM.. Reason: corrected text placement            #3
Janus
PF Mentor
Janus's Avatar
Janus is Offline:
Just to expand a little on what Janitor said.
Self inductance is generally caused by the magnetic field generated by the wire. In AC this field is always building, collapsing, reversing polarity, building etc. as the current switches back and forth in direction. The changing field reacts with the electrons in the wire opposing the current flow. This opposition is called inductive reactance, and acts somewhat like resistance(it is even measured in ohms). Inductive reactance directly increases with frequency and the inductance of the conductor by the formula:
LaTeX Code: X_{L}= 6.28fL
Thus double the frequency for any given conductor and you cut the currrent flow in half.
There is also capacitive reactance which decreases with frequency. this can also cause problems at high frequencies by bleeding current off. (the air gap between an conductor and ground can actually behave like a capacitor, shorting the current ot ground.
Old Mar27-04, 05:36 PM                  #4
Averagesupernova
Averagesupernova is Offline:
3 Ghz is not that fast in the general scheme of things. Transmission lines can carry signals much higher than that. Alot of the time though, microwave signals are carried long distances on something called waveguide which is the alternate to transmission lines. Think about this also: X-rays, gamma rays, visible light, all are part of the electromagnetic spectrum. They may not be carried on wires in the conventional manner, but they are still used and exploited by humans.
Old Mar27-04, 06:33 PM                  #5
Matt Jacques
Yes, I know they are all part of the electromagnetic spretrum, but it is paramount I know whether wires can handle such frequency.
Old Mar27-04, 06:59 PM                  #6
Averagesupernova
Individual 'wires' don't really handle the frequencies when they get that high. A transmission line would instead.
Old Mar30-04, 11:51 AM                  #7
wimms
wimms is Offline:
Interesting, we can put question not about parasitics or transmission lines, but about borderline between medium being conductive vs transparent/opaque.
I can't imagine radio waves of visible light frequency to be still conducted by _copper_, waveguides or not. So some sort of limit of frequency seems to be there. Though its very high and obviously together with attacking higher frequencies, new materials will be used.
Problem with very high frequencies is that space around wires becomes better conductor than wires themselves. Copper starts working better as insulator rather than conductor (waveguides?).
As to generating any frequency, all you need is positive feedback with specific phase shift, so that delayed signal adds up with itself, causing resonant oscillation. Parasitics definitely limits the frequency, as does speed of semiconductors.
Without any real qualification to state so, having only some electronics background, I'd guess that Terahertz maybe, petahertz no way for traditional copper based chip technologies. And there's no need either, all-optical computing is coming anyway.
Old Mar31-04, 04:23 AM                  #8
Ivan Seeking
PF Mentor
Ivan Seeking's Avatar
Ivan Seeking is Offline:
As an absolute upper limit, understanding of course that other factors mentioned might make this limit impossible, I would think that we might approximate something by looking at the atomic spacing in copper wire. I don't know how to calculate the proper wave function and such for a valence electron in copper [I think did once for about a week], but the average signal velocity is about 1/2 C. Doesn't this loosely imply a maximum frequency of transmission on the order of C/a; where a is the average distance between copper atoms?
Old Mar31-04, 09:44 AM                  #9
russ_watters
PF Mentor
russ_watters is Offline:
Averagesupernova, you may be confusing electricity (electrons moving in wires) with electromagnetic radiation (microwaves, light, etc.). Different issues.
Old Mar31-04, 12:22 PM                  #10
NateTG
NateTG is Offline:
Recognitions:
Homework Helper Homework Helper
I'm not an EE or EECS type, so I can't give you really good answers, but I know the following:
All wires act as inductors or capacitors depending on the length. As a result, certain lengths of wire will not conduct at particular frequencies. Although there are problems with short pulse propagation, the limiting factor on CPU's is typically transistor switching time, and not the maximum frequency that the wire can cary.
Typically computers work on detecting transitions. One of the things that happens is that as it propagates down a wire a sharp transition becomes less sharp, and at modern CPU speeds they can probably no longer be modeled with a simple step.
For typical applications, the preferred method for generating signals at a particular frequency is a piezoelectric crystal. In practice it's relatively easy to build circuits that will generate rapidly occilating signals, but those circuits are usually extremely sensitive. For example, hooking the output of a not gate into the the input of the not gate is liable to generate a high frequency signal - but the particular frequency depends on temperature, supply voltage, and probably ambient capacitence.
Old Mar31-04, 04:10 PM                  #11
Averagesupernova
No, I am well aware of the differences. I am simply gave an example of how power is transmitted within a confined area without the use of conventional wires.
Old Mar31-04, 05:16 PM                  #12
Njorl
Njorl is Offline:
Recognitions:
I've seen coaxial cables and striplines handle over 90 GHz. Things are very sensitive at these frequencies though. Touch a cable even lightly and you can change the signal passing through it.
I've found that up to 20 GHz, things are not too bad. I doubt PC's will get that fast though. I think parallellism will be the way to increase computer power. Once increasing parallellism is more cost effective than increasing clockspeed, electro-optic components will start replacing electronics. Optics are great for parallel processing.
Njorl
Old Mar31-04, 08:23 PM                  #13
chroot
PF Admin
chroot's Avatar
chroot is Offline:
You're essentially talking about the point where you have to stop thinking about electrical signals as electrons moving through wires and begin thinking about them as electromagnetic fields propagating through space.
The speed at which a signal can propagate through a wire actually has little to do with the wire itself -- it is mostly determined by the permittivity and permeability of the dielectric material surrounding the wire, since it impedes the creation of the magnetic field that needs to surround the wire as current flows. As you reach higher and higher frequencies, the wire's surroundings become much more important than the wire itself. Eventually you begin using waveguides, which are no longer wires but cavities -- the signal actually passes through vacuum (or air) in the form of electromagnetic waves.
- Warren
Old Mar31-04, 08:25 PM                  #14
chroot
PF Admin
chroot's Avatar
chroot is Offline:
NateTG:
Crystals are actually limited to about 200MHz for mechanical reasons. They become extremely small and hard to manufacture to good tolerance. Also, if you drop a 200MHz XO only a few inches, you'll shatter it. Some companies have had good success using a low-frequency crystal and filtering it to get only its high-order harmonics, though.
Generally, for high frequencies, a phase-locked loop is used.
- Warren
Old Apr3-04, 01:02 AM                  #15
flexifirm
flexifirm is Offline:
Remember one thing
Whoever said that transmission lines can handle higher frequencies than 3Ghz so it wasn't a big deal... remember one thing...
3Ghz is the frequency of the pulse wavetrain produced within the Penitum 4..... these are not sine waves... but have considerable higher order harmonics that produce a quasi-rectangular waveform.....
The critical constituent frequencies might extent well past the 30Ghz point (comparable to EHF radio band).
Now isn't the PENTIUM AMAZING???
Old Apr3-04, 01:02 PM                  #16
Averagesupernova
Transmission lines typically get lossier as the frequency increases. So your point about square waves doesn't completely hold water. You will eventually see the square edges of a waveform rounded of as the length of coax forms a low pass filter.
image image
Reply
Thread Tools
Similar Threads for: Maximum frequency of electrical pulses through wire?
Thread Thread Starter Forum Replies Last Post
maximum allowable current in a 12-gauge aluminum wire yanyin General Physics 3 Jun30-09 07:21 PM
electrical energy dissipated in resistance of a wire osugirl10 Introductory Physics 0 Feb18-08 03:52 PM
MRI testing for Electrical Brain pulses? justinreeves Medical Sciences 2 Dec23-07 09:33 PM
Measuring Temperature Of Electrical Wire StefanD Electrical Engineering 3 Oct24-07 06:42 PM
Frequency of wire? pivoxa15 Introductory Physics 11 Feb6-07 03:35 AM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
