Graph of Voltage vs Length for Moving Rod in Magnetic Field
The discussion focuses on the relationship between the induced voltage and the motion of a rod in a magnetic field, specifically using the equation EMF = -v*B*L. As the rod moves with a constant velocity v through a magnetic field of strength B, the induced voltage remains constant, resulting in a horizontal line on the graph of voltage versus length. This indicates that the voltage does not change with the length of the rod when moving at a constant speed, contrary to the initial assumption of a varying slope.
  • Understanding of electromagnetic induction principles
  • Familiarity with the equation for induced EMF
  • Basic knowledge of graphing functions
  • Concept of magnetic fields and their effects on moving charges
  • Study the principles of Faraday's Law of Electromagnetic Induction
  • Learn about the effects of varying magnetic fields on induced voltage
  • Explore the concept of Lorentz force in relation to moving charges
  • Investigate practical applications of induced EMF in electrical engineering
Students studying electromagnetism, physics educators, and electrical engineering professionals interested in the principles of electromagnetic induction and their applications.
Kites
Here is the problem:
Given a rod of Length L with one end centered at the origin and the other at y=L and given a magnetic field of strength B that points out of the page, what is the graph of the magnitude of the voltage read by a voltmeter as a constant velocity is applied to the rod as it moves across the field?
E_y, Induced = -v *B (electric field induced)
EMF = -v*B*L
I am having trouble visualizing the specifics of the motion, if it is a constant velocity should i expect a constant slope for the graph of the voltage with traits similar to X=Y or is it simply a constant value? (which seems unreasonable)
Can't you use this equation to derive the answer? ;-).
"EMF(voltage) = -v*B*L"
