KE in terms of P Pretty sure Ive got most of it
  • Thread starter Thread starter MJC8719
    Terms
The problem involves an explosion that breaks an object into two pieces with differing masses, specifically one piece being 1.60 times the mass of the other. The total kinetic energy released in the explosion is given as 7100 J, and the task is to express the kinetic energy of each piece in terms of momentum.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the conservation of momentum and how it relates to the velocities of the two pieces post-explosion. There are attempts to express the kinetic energies of the pieces in terms of their velocities and masses, with some participants questioning how to express these in terms of momentum. Others explore relationships between the kinetic energies of the two pieces.
There is an ongoing exploration of how to relate the kinetic energies of the two pieces and how to express them in terms of momentum. Some participants have offered guidance on comparing the kinetic energies and using known relationships to derive expressions. Multiple interpretations of the problem are being discussed, and participants are actively engaging with each other's reasoning.
Participants are working under the assumption that the pieces are at rest before the explosion and are trying to navigate the requirement to express kinetic energy in terms of momentum. There is also a noted confusion regarding the total energy value, with one participant acknowledging a mistake in the numerical value used.
MJC8719
An explosion breaks an object into two pieces, one of which has 1.60 times the mass of the other. If 7100 J were released in the explosion, how much kinetic energy did each piece acquire?
Heavier Piece
Lighter Piece
Express KE in terms of P
I think I have done most of the work here...its the last part of the problem that's tripping me up
Heres my work:
The explosion causes the piece (which I'm assuming explodes while at rest) to break into two pieces. Conservation of momentum states that they must go in opposite directions (you can verify this on your own). So, we have our first equation:
mv1 + 1.6mv2 = 0
mv1 = -1.6mv2
v2 = -v1/1.6
I use v1 for the velocity of the lighter piece, and v2 for the heavier piece. The energy of the explosion is transferred to the pieces and causes it to move, so the sum of the kinetic energies of the two pieces combined must equal 7100 J. Our second equation is:
1/2mv12 + 1/2 (1.6m)v22 = 7100
If we substitute v2 with what we got before with momentum conservation, then we can get the left hand side to be in terms of m and v1 only. We can't find the values of m and v1 directly, but we know that the kinetic energy (of the lighter piece) is 1/2mv12, which we can find after rearranging the equation so that it is in the form of kinetic energy:
1/2mv12 + 1/2(1.6m)(-v1/1.6)2 = 7100 J
1/2m(v12+v12/1.6) = 7100 J
1/2m(1.625v12) = 7100 J
1/2mv12 = 4370 J
Now here's where it starts to get a little tricky:
The final line reads: 1/2 mv1^2 = 4370.
So, we also then know that K = 1/2mv^2 = (1/2)(m^2v^2/m) = p^2/2m
Therefore, p^2/2m = 4370
So, the energy for lighter piece would then equal 4370 - p^2/2m and thus the energy for the heavier piece would just be 1- that.
Is this correct? I am slighty confused by the fact that my answer has to be in terms of P.
Thanks for the help
Try this. You know how v_1 and v_2 compare to each other. Use that to compare KE_1 to KE_2. Then use the total KE to find KE_1 and KE_2 explicitly.
Ok,
So if i understand you correctly you are saying that we know v2 = -v1/1.6.
We also know that KE1 + KE2 = 7100J
So, KE1 = 1/2mv1^2 and therefore KE2 = 1/2(1.6m)v2^2 but we know that v2 = -v1/1.6 so therefore we can say that
KE2 = (1/2)(1.6m)(-v1/1.6^2)
So we can then have the equation
1/2mv1^2 + (1/2)(1.6m)(-v1/1.6^2) = 7100
Is this correct so far??
If we continue this we would get
1/2 mv1^2 + (0.8m)(v1^2/2.56) = 7100
1/2 mv1^2 + .31250 v1^2 = 7100
p^2/2m + .31250v1^2 = 7100
And this is where i get stuck if i have done the above correctly... your help is really appreciated
MJC8719 said:
Ok,
So what is KE2 in terms of KE1?
(Forget about expressing KE in terms of P; that's not helpful here.)
Hmm,
So if I understand this then if we simplify
KE2 we find that it equals 0.31250mv1^2.
KE1 then equals 0.5mv1^2.
So if we make KE1 ="1" or KE1 - mv1^2 then KE2 = .0625mv1^2 of KE1.
Is this what you mean. If so, then could you give me a hint as to what the next step is?
MJC8719 said:
Hmm,
Now express KE2 in terms of KE1. (Just like you wrote v2 in terms of v1: v2 = v1/1.6.)
Suddenly, it clicked Doc...Thanks for the help. I was getting hung up on the whole solve for p part
I think the "write K in terms of p" is just a hint:
total momentum before = total momentum after so
0 = M v - m V where M = 1.60 m so V = 1.60 v
Now total energy:
E total = (1/2) M v2 + (1/2) m V2 or
E total = (1/2) M v2 + (1/2) (M/1.60) ( 1.60 v)2
E total = (1/2) M v2 + 1.60 (1/2) M v2 or
E total = ( 1 + 1.60 ) (1/2) M v2 notice that the last bit is just the KE of the larger piece so
E total = 2.60 K of larger piece so
71000 / 2.60 = K or larger piece or
K of larger piece = 27308 J and the smaller piece gets the rest,
71000 - 27308 = 43692 J
Now i Understand it...though i realizied i added an extra zero and made it 71000 instead of 7100.
Thanks for the help
11K
  • · Replies 29 ·
  • · Replies 19 ·
11K
10K
