Solve Diff. Equation y"-y=1/(sin) with Expert Help - Get Started Now!
  • Thread starter Thread starter sunshine17
The discussion revolves around solving the differential equation y'' - y = 1/(sin), with participants exploring its classification and potential methods for solution.
  • Exploratory, Assumption checking
  • Participants question the nature of the differential equation and suggest identifying the appropriate method for solving it. There is also a suggestion to clarify the expression "1/(sin)" as potentially meaning "1/(sin x)".
The discussion is ongoing, with some participants providing guidance on the need to show work and consider the equation's linearity. Multiple interpretations of the equation's components are being explored.
There is a mention of the thread being moved to the homework section, indicating adherence to forum rules regarding homework help.
sunshine17
I can't solve this equation y"-y=1/(sin) , pls help me.
Thank you in advanced:)
Sounds like homework problem. You'll have to show some work first. But for starters try asking yourself what kind of DE it is, and what method should be applied.
(btw, I've requested that this be moved to the homework section)
Thread moved. Thanks for the heads-up, ranger.
Can we assume that "1/(sin)" should be "1/(sin x)"? If so that is a linear differential equation. There is a standard formula for the integrating factor. Use it!
  • · Replies 18 ·
