Finding the Maximum Area of a Quadrilateral with Perpendicular Diagonals
  • Thread starter Thread starter BayernBlues
The problem involves finding the maximum area of a quadrilateral with perpendicular diagonals, given that the sum of the lengths of the diagonals is 6 cm. The original poster attempts to express the area in terms of the diagonal lengths and seeks to maximize it using differentiation.
  • Exploratory, Mathematical reasoning
  • The original poster formulates the area as a function of the diagonal lengths and expresses it in terms of one variable. They express uncertainty about the differentiation process and seek clarification on finding extrema.
Participants are engaged in exploring the differentiation of the area function. Some guidance has been offered regarding the differentiation process, and there is an ongoing examination of the results obtained from the differentiation.
There appears to be confusion regarding the application of differentiation and the interpretation of the results, particularly concerning the signs and values derived from the calculations.
BayernBlues
The diagonals of a quadrilateral are perpendicular. The sum of the lengths of the diagonals is 6cm. What is the maximum area of such a quadrilateral?
let x and y be the lengthes of the diagonals. Then the area of the quadrilateral is calculated by:
a = ½ * x * y
From the given conditions you know: x + y = 6 ==> y = 6 - x
Plug in the term for y into the first equation:
a(x) = ½*x*(6 - x) = -½x² + 3x
I do not know what to do from here. I know that there is a graphing method but I'd rather do it through differentiation so could someone do the solution that way. The answer should be y=3 and x=3 so the dimensions are 3 x 3 I think.
Do you know how to find the extrema(maxima and minima) of a given function with respect to a variable?
I'm more confused now. If I differentiate a(x), this is what happens
a'(x)=2/2 x + 3
0= x + 3
x= -3
y= 6 - x
y = 6 - (-3)
y= 9
So the dimensions are 9 x 3? That doesn't seem right.
You missed the minus sign.
6- -3 is 9.
I'm going over it and that's still the only answer I get for some reason.
I meant when you differentiated the original equation.
  • · Replies 27 ·
  • · Replies 25 ·
