Static problem with three cylinders
  • Thread starter Thread starter sangol
    Cylinders Static
The discussion focuses on the equilibrium conditions for a system of three identical cylinders arranged in a triangle, with specific attention to the friction coefficients between the cylinders and the ground. The analysis reveals that for the system to remain in equilibrium, the friction coefficient between the cylinders (u1) must be approximately 0.268, while the friction coefficient between the cylinders and the ground (u2) must be around 0.089. The solution is derived from a series of equations involving normal forces and frictional forces acting on the cylinders, confirming that the friction between the cylinders is more critical for stability than that between the cylinders and the ground.
  • Understanding of static equilibrium concepts
  • Knowledge of friction coefficients and their implications
  • Familiarity with normal force calculations
  • Ability to solve systems of equations in physics
  • Study the principles of static equilibrium in multi-body systems
  • Learn about the role of friction in mechanical stability
  • Explore advanced topics in mechanics, such as the effects of varying friction coefficients
  • Investigate numerical methods for solving complex equilibrium problems
Students of physics, mechanical engineers, and anyone interested in understanding the dynamics of static systems involving friction and equilibrium conditions.
sangol
Static problem
Three identical cylinders of mass m are arranged in a triangle as shown:
http://img440.imageshack.us/img440/2040/cylindersjo4.jpg
The friction coefficient between cylinders is "u1" and between cylinders and ground "u2". What condition must satisfy "u1" and "u2" to remain the system in equilibrium ?
N1 is normal force between left cylinder and top cylinder (Fr1 friction force in the same point (u1*N1))
N2 is normal force between right cylinder and top cylinder (Fr2 friction force in the same point (u1*N2))
N3 is normal force between left cylinder and right cylinder (Fr3 friction force in the same point (u1*N3))
N4 is normal force between ground and left cylinder (Fr4 friction force in the same point (u2*N4))
N5 is normal force between ground and right cylinder (Fr5 friction force in the same point (u2*N5))
solve({(1/2)*N1*sqrt(3)+(1/2)*N2*sqrt(3)+(1/2)*Fr2-(1/2)*Fr1-m*g = 0, (1/2)*Fr1*sqrt(3)+(1/2)*N1+(1/2)*Fr2*sqrt(3)-(1/2)*N2 = 0, N4+Fr3+(1/2)*Fr1-(1/2)*N1*sqrt(3)-m*g = 0, Fr4-N3-(1/2)*Fr1*sqrt(3)-(1/2)*N1 = 0, N5-m*g-Fr3-(1/2)*N2*sqrt(3)-(1/2)*Fr2 = 0, N3-Fr5+(1/2)*N2-(1/2)*Fr2*sqrt(3) = 0,Fr1+Fr2 = 0, Fr4+Fr3+Fr1 = 0, Fr2+Fr3-Fr5 = 0, Fr1 = u1*N1, Fr2 = u1*N2, Fr3 = u1*N3, Fr4 = u2*N4, Fr5 = u2*N5}, {u1, u2, Fr1, Fr2, Fr3, Fr4, Fr5, N1, N2, N3, N4, N5})
{Fr2 = 0, Fr3 = 0, Fr1 = 0, Fr4 = 0, u1 = 0, N5 = (3/2)*m*g, N4 = (3/2)*m*g, N3 = -(1/6)*m*g*sqrt(3), N1 = (1/3)*m*g*sqrt(3), N2 = (1/3)*m*g*sqrt(3), u2 = 0, Fr5 = 0}
:rolleyes:
Possible interpretation of the result:
The solution is correct (i suppose) to frictionless case, so with friction:
Fr4 + N3 = 0 -> u2 * N4 = - N3 -> u2 * (3/2)*m*g = (1/6)*m*g*sqrt(3) -> u2 = sqrt(3)/9 ~ 0.19 ?
u2 = 0.19 and u1 = 0 is sufficient to equilibrium !?
Ok i solved it !
If you put u1, u2, u3, u4, u5 as friction coefficients (instead of u1 and u2) in equations:
:[/B]
solve({(1/2)*N1*sqrt(3)+(1/2)*N2*sqrt(3)+(1/2)*Fr2-(1/2)*Fr1-m*g = 0, (1/2)*Fr1*sqrt(3)+(1/2)*N1+(1/2)*Fr2*sqrt(3)-(1/2)*N2 = 0, Fr1+Fr2 = 0, N4+Fr3+(1/2)*Fr1-(1/2)*N1*sqrt(3)-m*g = 0, Fr4-N3-(1/2)*Fr1*sqrt(3)-(1/2)*N1 = 0, Fr4+Fr3+Fr1 = 0, N5-m*g-Fr3-(1/2)*N2*sqrt(3)-(1/2)*Fr2 = 0, N3-Fr5+(1/2)*N2-(1/2)*Fr2*sqrt(3) = 0, Fr2+Fr3-Fr5 = 0, Fr1 = u1*N1, Fr2 = u2*N2, Fr3 = u3*N3, Fr4 = u4*N4, Fr5 = u5*N5},{u1, u2, u3, u4, u5, Fr1, Fr2, Fr3, Fr4,Fr5, N1, N2, N3, N4, N5})
3. Solutions:
N1 = (1/2)*m*g
N2 = (1/2)*m*g
N3 = 0
N4 = (3/2)*m*g
N5 = (3/2)*m*g
Fr1 = 1/2*(sqrt(3)-2)*m*g
Fr2 = -1/2*(sqrt(3)-2)*m*g
Fr3 = 0
Fr4 = -1/2*(sqrt(3)-2)*m*g
Fr5 = -1/2*(sqrt(3)-2)*m*g
u1 = -2+sqrt(3) ~ -0.268 (negative because Fr1 have opposite direction)
u2 = 2-sqrt(3) ~ 0.268
u3 anyone
u4 = -(1/3)*sqrt(3)+2/3 ~ 0.089
u5 = -(1/3)*sqrt(3)+2/3 ~ 0.089
So, the solutions are:
Friction coefficient between cylinders: 0.268
Friction coefficient between cylinders and ground: 0.089
I though that friction was more important between ground and cylinders that between cylinders for stability but the result show opposite to my logic. :smile:
If someone finds any error in operations, please reply the thread.
Greetings!
  • · Replies 21 ·
