Calculating Work for Pumping Water from a Hemispherical Tank
  • Thread starter Thread starter drklrdbill
    Integral Work
The work required to pump water from a hemispherical tank with a radius of 5 feet is calculated to be 210,309.12 foot-pounds. The integral initially evaluated, pi(125x/3)(5-x)^2, was incorrectly focused on volume rather than work. The correct approach involves using the formula W = mgh, where m is the mass of the water, g is the acceleration due to gravity (32.2 ft/s²), and h is the height (5 feet). The mass of the water is determined using the volume of the tank, calculated as (2/3 * pi * r³), leading to a total mass of 1304.16 pounds.
  • Understanding of calculus, specifically integration techniques.
  • Familiarity with physics concepts such as work, mass, and gravity.
  • Knowledge of the formula for the volume of a hemisphere.
  • Basic understanding of units of measurement in physics (e.g., foot-pounds).
  • Study the derivation of the volume formula for a hemisphere: V = (2/3)πr³.
  • Learn about the relationship between weight, mass, and density in fluid mechanics.
  • Explore the concept of work in physics, particularly in fluid dynamics.
  • Practice solving similar problems involving work and integration in calculus.
Students studying calculus and physics, engineers working with fluid dynamics, and anyone interested in understanding the principles of work and energy in practical applications.
drklrdbill
A hemispherical tank of radius 5 feet is situated so that its flat face is on top. It is full of water. Water weighs 62.5 pounds per cubic foot. The work needed to pump the water out of the lip of the tank is ? foot-pounds.
I tried evaluating the integral of pi(125x/3)(5-x)^2 from 0 to 5.
What am I doign wrong? I cannot figure this out for the life of me, spent about the last hour on a seemingly simple problem that continues to stump me.
Calculating the work for pumping water from a hemispherical tank can be a bit tricky, but it looks like you're on the right track with your integral. However, there are a few things you may be doing wrong that are causing you to get stuck.
Firstly, it's important to note that the integral you are evaluating is for the volume of the tank, not the work needed to pump the water out. In order to calculate the work, we need to consider the weight of the water being pumped out of the tank.
To do this, we can use the formula W = mgh, where W is the work, m is the mass of the water being pumped, g is the acceleration due to gravity (32.2 ft/s^2), and h is the height the water is being pumped to. In this case, h would be the radius of the tank, or 5 feet.
Next, we need to calculate the mass of the water being pumped. Since we know the weight of water per cubic foot (62.5 pounds), we can use the formula m = V * p, where m is the mass, V is the volume, and p is the density. In this case, the volume of water being pumped would be the volume of the hemispherical tank, or 2/3 * pi * r^3, where r is the radius of the tank (5 feet). So the mass of the water being pumped would be (2/3 * pi * 5^3) * 62.5 = 1304.16 pounds.
Now, we can plug in these values into the formula W = mgh to get the work needed to pump the water out of the tank. This would be (1304.16 pounds) * (32.2 ft/s^2) * (5 feet) = 210,309.12 foot-pounds.
So it looks like the work needed to pump the water out of the lip of the tank would be 210,309.12 foot-pounds. I hope this helps clarify the process for you. Keep practicing and don't get discouraged, math can be tricky at times but with practice and patience, you'll get it!
  • · Replies 56 ·
  • · Replies 21 ·
11K
