Proving Equivalence Relations with a Given Condition
  • Context: Undergrad
  • Thread starter Thread starter Dream
The discussion revolves around proving that a specific relation defined on a set A is an equivalence relation. The relation R is defined by the condition (x1,y1)R(x2,y2) if x1+y1=x2+y2. Participants explore how to demonstrate the reflexive, symmetric, and transitive properties required for equivalence relations.
  • One participant expresses confusion about how to use the condition x1+y1=x2+y2 to prove the properties of equivalence relations.
  • Another participant confirms that equality is an equivalence relation on integers, outlining the properties but makes a correction regarding the transitive property statement.
  • A later reply emphasizes the importance of the condition x1+y1=x2+y2 in establishing the properties of reflexivity, symmetry, and transitivity.
  • Examples are provided to illustrate how to verify each property using specific pairs from the set A.
  • There is a suggestion that generating specific examples can help build confidence in proving the general case.
Participants generally agree on the need to demonstrate the properties of equivalence relations, but there is no consensus on the best approach to proving the relation R is an equivalence relation. Some participants provide examples while others seek clarification on the use of the defining condition.
Some participants express uncertainty regarding the application of the condition x1+y1=x2+y2 in the context of proving the properties of equivalence relations. There are also corrections made to earlier statements without resolving the overall proof process.
This discussion may be useful for students or individuals studying equivalence relations in mathematics, particularly those looking for examples and clarification on how to prove such properties.
Dream
Hi,
Here is my question. I need to prove the following an equivalence relation.
Let A = {1,2,3,4,5} X {1.2,3,4,5} and define a relation R on A by (x1,y1)R{ x2,y2) if x1+y1=x2+y2.
I am bit confused how to use the condition x1+y1=x2+y2 to prove for transitive, symmetric and reflexive properties.
Please help.
Thanks
Can you show that "=" is an equivalence relation on the integers?
Thanks for your reply John.
Ya sure. If I have got your question correctly. I have done this.
Let S be a nonempty set of integers and let
equality = be our relation. Then = is an equivalence relation on
S since
(i) a = a for all a S,
(ii) if a = b, then b = a (for all a,b),
(iii) if a = b and a = b then a = c (for all a,b,c ).
I am eager to know whether I am correct on this or not.
I think on you probably meant: (iii) If a = b and b = c then a = c. The point is, at any rate, that it's easy to see that x1+y1 and x2+y2 from your original post are both integers.
Dream said:
Hi,
Please help.
Thanks
The relation R that you defined is an equivalence relation on A;
it is not, however, the equality relation on A.
I suggest you state the reflexive, symmetric and transitive properties for binary relations in general.
Then verify that R satisfies all three.
Thanks fopc! but what is the use of condition x1+y1 = x2+y2 ?
Use? Who knows. It's just an example to see if you can prove something is an equivalence relation.
You've not written a proof yet.
So, does (x,y)R(x,y)?
Does (x,y)R(u,v) imply (u,v)R(x,y)?
Does (x,y)R(u,v) and (u,v)R(s,t) imply (x,y)R(s,t)?
Here's some supplementary information to consider.
R is a subset of AxA.
x1+y1 = x1+y2 is the property or predicate (call it P) that defines R, i.e.,
R = {((x1,y1),(x2,y2)) | x1+y1 = x2+y2} (loosely stated).
What use is P? P must be used to establish the three properties in question.
There is no escape here. It must be used.
What I think you'll see is that the properties in question will be inherited
from P itself. Think about '='.
Invariably, for me at least, generating specific examples gives confidence
that something can be established in general.
Here's an example for each property.
Reflexivity:
Ask yourself, is every member of A in relation with itself (all 25 of them)? Of course, yes.
For example, is ((1,2),(1,2)) in R?
Symmetry:
Example: Clearly, ((3,4),(5,2)) is in R. Then we must have that ((5,2),(3,4)) in R and it is.
Transitivity:
Example: Clearly, ((5,1),(4,2)) and ((4,2),(3,3)) are in R. Then we must have ((5,1),(3,3)) in R and it is.
Thanks a lot... :-)
  • · Replies 35 ·
