Calculate Projectile Velocity: Magnitude & Direction
The problem involves calculating the initial velocity of a diver who springs from a board into the water, given her final speed and angle of entry. The subject area pertains to kinematics and projectile motion.
  • Participants discuss the use of kinematic equations to find the initial velocity, with some attempting to derive it from the final velocity and angle. Questions arise about the position function and the application of various kinematic equations.
There is an active exchange of ideas regarding the calculations involved, with some participants providing specific equations and methods while others express uncertainty about their approaches. Guidance has been offered on finding both the x and y components of the initial velocity.
Some participants express confusion about the component method and the application of kinematic equations, indicating a need for clarification on these concepts. There is also mention of differing results in calculations, highlighting potential misunderstandings in the problem-solving process.
scw287
A diver springs upward from a board that is three meters above the water. At the instant she contacts the water her speed is 9.00 m/s and her body makes an angle of 81.0° with respect to the horizontal surface of the water. Determine her initial velocity, both magnitude and direction.
magnitude m/s
direction °
Here's what I've tried to do: I tried to solve for the initial velocity by using the kinematics equation v^2=vo^2+2*a*x
vo=1.174<<initial velocity
Now I need to find the magnitude and the direction, I think you use tan-1 and pythagorean theorem but I don't really understand the component method very well. Could you please help me get on the right track for this problem. All help will greatly be appreciated.
do you know the position function?
no I haven't heard of the position function.
do you know the kinematic equations?
How did you get the initial y velocity 1.174 m/s?
Yes I know the kinematics equations x=volt+a/2at^2
x=1/2(vo+v)t
v=vo+at
v^2=vo2+2axI got 1.74m/s for the initial velocity by using the fourth equation. I am not positive that I did it right. Not sure what to do next!
in the y-direction ...
v_{fy}^2 = v_{oy}^2 - 2g(Delta y)
v_{oy} = sqrt[v_{fy}^2 + 2g(Delta y)]
v_{oy} = sqrt[(9*sin(81))^2 + 2(9.8)(-3)] = approx 4.5 m/s
velocity in the x-direction is a constant ...
v_x = 9*cos(81) m/s
you now have both x and y components of the initial velocity ... finish up.
Thanks for all of your help!
Yes, I thought that you did use the fourth equation, but I got a different answer. I was hoping that you would show more exactly how you susbtituted to get to it so that we can compare notes.
