What rating toggle switch do I need for my lawn mower's kill switch replacement?
  • Thread starter Thread starter wxrocks
The discussion revolves around the replacement of a lawn mower's kill switch with a toggle switch. Participants explore the electrical ratings needed for the switch, safety concerns, and alternative methods for stopping the engine. The conversation includes technical specifications, personal experiences, and suggestions for modifications.
  • One participant expresses frustration with the current kill switch design, which grounds the spark to the chassis and has proven unreliable, leading to multiple replacements.
  • Another participant questions the reliability of using a toggle switch and asks for clarification on how the current switch fails.
  • A participant describes the original switch mechanism, highlighting its safety function and the issues with its actuation that lead to wear and failure.
  • One contributor suggests that the voltage for the toggle switch is likely low (12 VDC) and that a switch rated for 5 to 10 amps should suffice, proposing a spring-loaded switch as an alternative to maintain safety.
  • Another participant offers a method to stop the engine by manipulating the throttle linkage, noting it is less safe than a kill switch but easier to implement.
  • A historical reference is made to an older mower design that used a metal strip to ground the spark plug, suggesting it as a potential low-cost solution.
  • One participant proposes replacing the low voltage switch with a more reliable toggle switch, indicating that most kill switches ground the points rather than the spark plug.
  • Another participant introduces a new issue regarding the mower's movement, asking for clarification on whether the motor continues running when the mower stops moving.
Participants express differing views on the reliability and safety of using a toggle switch versus the existing kill switch. There is no consensus on the best approach to replace the kill switch, and alternative methods are also discussed without agreement on their effectiveness.
Participants mention various assumptions about voltage and current ratings, but these are not universally agreed upon. The discussion includes personal anecdotes and suggestions that may not apply to all mower models.
Individuals interested in lawn mower maintenance, electrical switch specifications, and alternative engine shut-off methods may find this discussion relevant.
wxrocks
Ok -- My lawn mower has a lame kill switch that creates a ground to the chassis when the handle is released. I am on my third switch and I am sick of tearing it apart to replace it.
I want to replace it with a toggle switch that will ground the spark to ground when I want to shut it off. I know the spark is high voltage. I am wondering what rating I should get the toggle switch so I don't fry it.
I think the ground wire is about 16 guage, so I am assuming a 600V 10A switch should be plenty. Am I over or under estimating it?
Thanks!
a toggle switch is just asking for bad things to happen. how does the current switch keep breaking?
I know the handle release is for safety -- but this model has this weird switch that is basically 1/2 a paper clip in a plastic container that is squeezed together to form a connection from the magnet producing the sparks to the chassis rather than the spark plug. the problem is the way the switch is actuated either gets jammed, the hook comes loose, or the switch gets worn.
I understand the safety concern, but I just want an easier way to shut this off over having the switch wear out and then having to pull the spark plug wire off. In the end, this will be safer than not knowing if the original switch won't work.
Hi wxrocks,
The toggle switch isn't high voltage, it's no more than 12 VDC, and amps are very low too, less than 10 amps, probably 5 or less. Just about any switch should work.
You could get a spring loaded switch that makes contact when you release the button if you want to retain the safety feature.
You can also move the small throttle linkage on the side of the carburator, that will stop the engine by starving the engine of gas. Its not as safe as a kill switch, but it is a lot easier than installing a new switch. If you move the linkage one way and the engine revs up, move it the other way and the mover will die. The linkage is located just below the air filter, and may become hot after you have been mowing for sometime.
One of the older (60's) mowers that I remember had a strip of springy metal like from a soup can that wrapped around the head of the spark plug just on the near side of the connector boot, in contact with the electrode, and stuck up in the air. When the owner wanted to stop the thing, he just pushed the strip against the engine housing with his foot. I don't know if it was jury-rigged or if the thing was bought that way, but it worked. Maybe you could try that before mucking about with switches. It won't cost you anything.
Why not replace the low voltage switch that is breaking with a good toggle switch?
Most kill switches, ground the points not the spark plug.
when ever i put my lwn mower in forwerd gear it goes about a foot then stops wjhat could that be
Does the motor keep running?
Or does that stop also?
  • · Replies 21 ·
334K
9K
  • · Replies 129 ·
82K
28K
9K
