| Thread Closed |
proton anti-proton annihilation. |
Share Thread | Thread Tools |
| Jun6-07, 04:45 AM | #1 |
state why p + p_bar --> 1 photon is forbidden 2. Relevant equations 3. The attempt at a solution I have checked all quantum numbers and they are okay. I wondering altough if p_bar has intrinsic parity -1 (p has parity +1)?? According to the soloution, it is forbidden because of energy and momentum conservation. I have not been giving a single word about the production conditions and so forth. HOW can this (E and p) be violated if I choose whatever annihilation condition so that p and E is not violated??!! |
| Jun6-07, 04:50 AM | #2 |
Mentor
Which special frame of reference is often used in collision problems?
| Jun6-07, 06:20 AM | #3 |
Center of mass. But that is not statet OFTEN CM frame is used. Sometimes I just want to **** my teachers.. :P
| Jun6-07, 06:34 AM | #4 |
Mentor
Centre of momentum frame. Is there a center of momentum frame for a system consisting of of a proton and an anti-proton? Is a there center of momerntum frame for a system consisting of a single photon?
| Jun6-07, 08:47 AM | #5 |
And who are saying that the proton and antiproton has EXACTLY opposite momenta?
What if for example p has little more momentum than the p_bar? Is not one-photon creation possible then? And if two photons are created, then parity is violated? So there must be a three photon creation in order to conserve all, IF the p and p_bar is travelling at exaclty the same momenta (but opposite). Is that right? |
| Jun6-07, 09:03 AM | #6 |
I had a question similar to your one I had to solve. The question was "Show that a photon cannot spontaneously disintegrate into and electron-positron pair". The lecturer mentioned I could tackle this problem using four-momentum or classical conservation of energy and momentum.
I used the classical way, so I didn't have to deal with tensors ![]() An assumption is made at the start, that the electron-positron pair don't move at relativistic speeds. Thus, a classical "Newtonian" means can be applied to the question. So, all I did was work out the initial/final energy and momentum of the system. Using the conservation of energy equation I substituted it into the conservation of momentum equation and solved for the velocity v (This was the velocity of the electron and positron) . I found v to equal 2c, where c is the speed of light. This implies that the electron and positron was going at twice the speed of light which cannot happen. This implies that the photon cannot spontaneously disintegrate. I know this wasn't the same as your question, but I think the logic is the same but reversed and you may obtain a final velocity less than c. Not too sure though. I hope this helps. |
| Jun6-07, 09:12 AM | #7 |
But protons are not elementary particle systems.
And if the photon has enough energy and is in the field of a nucleus, pair production is posssible. The correct analogy would be "why can not an electron and positron annihilate and produce a single photon" I know that two photons are produced, but that would violate parity if the electron and positron has relative angular momentum = zero. ? I really love to think of the problems on a deeper level than just knowing the answer. I want to understad these things how they work. If we look att this electron positron annihilation: e + posit = 2 fotons parity_initial = (-1)(+1) (if zero angular momentum) parity_final = (-1)(-1) i.e parity is violated?? I did the similar for the p + p_bar and either one or three photons are emitted, depending on how p and p_bar moves relative each other. How would all the pro's out there solve this?;) |
| Jun6-07, 09:23 AM | #8 |
Sorry mate, I don't seem to know enough about parities. I remember being it mentioned in quantum.
The question I got was from a relativistic dynamics unit. Which topic of physics are you studying at the moment? |
| Jun6-07, 11:07 AM | #9 |
I wanna have all points on the exam tomorrow =( but exersices hwere no background information or descriptions of the collision and decays, I often want to give all possible solutions, because I am never sure what the teacher want me to answer... as in this p + p_bar annihilation, why do they have to collide with exactly the same momenta (but reverse)? There is nothing in the text.. it really makes me angry :P So my question for everyboy who know this stuff; can the p and p_bar create a single photon if any of them has higher momentum than the other one? And if they collide with same but opposite momenta, do they create 3 photons to conserve parity? |
| Jun6-07, 02:03 PM | #10 |
Mentor
If the total spatial momenta of the proton anti-proton system is non-zero, then you can always transform to a frame in which the total spatial momentum is zero. The spatial momentum of a single photon is non-zero in all frames. |
| Jun6-07, 03:05 PM | #11 |
Recognitions:
If you don't like thinking about a special frame then think about a general frame and 4 vectors. Forgetting factors of 'c', we have E^2-p^2=m^2. So in these units the spatial momentum of a proton is always less in magnitude than its energy. Now ask yourself whether two such vectors can add together to yield a vector like the photon with E=p. Clearly not, it seems to me anyway.
| Jun6-07, 03:29 PM | #12 |
okey, than I am fine =) Thanks!
We have not talked about this during the lecutres or lessons. And nothing in the book either.. So how would then the p + p_bar annihilate? 2 or 3 photons? |
| Jun6-07, 03:44 PM | #13 |
Recognitions:
Either should be kinematically possible, though I'm really not sure. I think in general real world ppbar annihilation is pretty messy since they are composite particles. Ask the folks at CERN or the Tevatron.
| Jun6-07, 04:01 PM | #14 |
okey, but is 2photon creation possible due to parity?
each photon has negative parity right? And no relative angular momentum between p and p_bar should give them negative parity. 2photons would have positive. am I totaly lost now? =) |
| Jun7-07, 02:31 PM | #15 |
Recognitions:
p and p_bar can annihilate to two photons. p and pbar in the S=0, L=0 state have the same Q numbers as the pi_0. The negative parity means that the photons will have polarization corresponding to the pseudoscalar E.B. This is how Yang suggested the measurement of the parity of the pi_0 fifty years ago. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: proton anti-proton annihilation.
| photon-proton/ proton-electron interactions | Quantum Physics | 34 | ||
| Positron and anti-proton existence | High Energy, Nuclear, Particle Physics | 1 | ||
| Is neutron-neutron fusion easier to facilitate than proton-proton | General Physics | 5 | ||
| relativity - proton-proton collision | Advanced Physics Homework | 2 | ||
