Maximizing Winter Sunlight for Your Solar Project: Tips from a DIY Enthusiast
  • Context: High School
  • Thread starter Thread starter philipc
    Light Sun
The discussion revolves around maximizing sunlight for solar projects, specifically focusing on understanding solar insolation values, the conditions under which photovoltaic (PV) panels achieve their rated output, and the relationship between solar insolation and panel efficiency. The scope includes practical applications for DIY solar projects and technical inquiries related to solar energy calculations.
  • One participant, Philip, seeks information on the minimum sunlight levels for solar calculations, noting the lack of resources that provide this data.
  • Another participant suggests using the term "insolation" to find relevant data, providing a link to a resource that lists minimum, average, and maximum insolation for US cities.
  • Philip expresses gratitude for the information but notes the absence of data for Houston, indicating a need for more comprehensive resources.
  • A question is raised about the conditions under which a PV panel achieves its rated wattage, with a suggestion that this information can be found in the panels' datasheets.
  • Another participant speculates that the rated output of PV panels is based on maximum expected insolation, but acknowledges uncertainty about the specifics.
  • A participant cautions against relying solely on insolation numbers, providing specific figures related to solar panel output and questioning how different light frequencies affect solar cell efficiency.
  • There is a suggestion that only a fraction of high insolation values is effective for solar cells, with an estimate of around 10% being applicable.
Participants express varying degrees of uncertainty regarding the conditions for PV panel ratings and the relationship between insolation and solar cell efficiency. There is no consensus on the exact conversion factors or the implications of different light frequencies on solar panel performance.
Participants reference specific values and conditions related to solar insolation and panel efficiency, but the discussion remains open-ended with unresolved questions about the conversion factors and the applicability of different light frequencies.
philipc
I'm building a solar powered project to light a room. From what I find on the internet, the average of sun light is given. It seems like to make my calculations I need to know what the minimum amount of sunlight could be. I haven't been able to find a website that shows the min and max sun light for a region, just the yearly average. Anyone ever done such a project?
Thanks
Philip
Science news on Phys.org
I googled solar power insolation, and got lots of useful hits. Here's one with min/avge/max for US cities:
http://www.solar4power.com/solar-power-insolation-window.html
The key to any google search is knowing a helpful unique keyword. In this case, it was "insolation", which is the term for the inbound solar flux. Hope that helps.
Thanks that is exactly what I was looking for. To bad they left off the 4th largest city, Houston? But now I can use your key words.
Thanks again
Philip
I would like to add one more question, when a PV panel is rated for X watts, under what conditions can I assume it will achieve these numbers? Is there some standard whr/m2 that PV panels are rated?
Sorry, I don't know the answer to that. You could probably figure it out from the datasheets for the panels, if you can find those at the manufacturers' websites.
My guess would be the output would be stated for the max insolation that could be expected, whatever the max is in the tables that you've found. That's usually how marketing speak works. It's not like the solar panels are going to blow up or overheat if they exceed their "maximum" power output :cool:
I'd be careful of those numbers.
A 170w Solar Panel covers about 1 sq meter.
The doc lists solar insolation as being 800w sq meter for a cell efficiency of about 21%.
The worst case shown above is 1000w while the best case is around 8000w.
I suspect the difference is that solar cells only work with certain frequencies of light.
While I've been poking around at this stuff lately I haven't gotten around to figuring out how one set of numbers relates to the other.
Anybody know the conversion factor?
What part of say 4000w is in frequencies applicable to solar cells?
Edit: I suspect it is around 10%.
  • · Replies 21 ·
