Batch Distillation: Packing vs Plates for Reboiler of 250 Litres
  • Thread starter Thread starter abhijeetrana
    Batch Distillation
The discussion revolves around the choice between using packing or plates for a reboiler in a batch distillation setup of 250 liters. Participants explore considerations related to efficiency, ease of cleaning, cost, and the need to prevent cross-contamination when switching between different mixtures.
  • Debate/contested, Technical explanation, Conceptual clarification
  • One participant seeks advice on whether to use packing or plates for a distillation column, emphasizing the need for easy cleaning to avoid cross-contamination.
  • Another participant questions if a plate column offers higher efficiency for distillation compared to packing.
  • A different participant suggests that packing may be easier to clean than plates.
  • It is proposed that if the packing can be easily removed and replaced, it could simplify the process, as packing is generally not too expensive and can be cleaned and stored for future use.
Participants express differing views on the efficiency of plate columns versus packed columns and the ease of cleaning. No consensus is reached regarding the best choice for the reboiler.
The discussion does not clarify specific assumptions regarding the efficiency of packing versus plates, nor does it address the cost implications in detail. The effectiveness of cleaning methods and their impact on operational efficiency remain unresolved.
abhijeetrana
I need to know a few things. I am doing my internship and have been given a problem with very limited information. I have to decide whether to use packing or plates. The tower is to be used for several different mixtures. So everytime it has to be washed completely, whenever a new separation is to be done. So the internals of the tower have to be as such that they can be washed easily so that there is NO CROSS CONTAMINATION. And there is cost limit too. Cant afford a too expensive column too beacuse it is not a big thing. It is for a reboiler of 250 litres. Any suggestion?
I don't know, do you think a plate column has a higher efficiency in doing the distillation?
Easier to clean packing than plates I would have thought.
If the column packing can be easily removed between distillations and replaced with fresh packing (while the old packing is being prepared for the next batch), it would seem that the packed column would be the easier route. Column packing is usually not too expensive and should be able to be easily cleaned (solvent rinse followed by drying) and stored for the next run.
  • · Replies 19 ·
11K
