Thread Closed
a coil of wire is connected to an uncharged capacitor in a magnetic field....
Share Thread Thread Tools
Jun7-07, 10:29 PM   #1
A 10-turn coil of wire having a diameter of 1.0 cm and a resistance of 0.20 ohms is in a 1.0 mT magnetic field
with the coil oriented for maximum flux. The coil is connected to an uncharged 1.0 microFarad capacitor rather than to a current meter. The coil is quickly pulled out of the magnetic field. Afterward, what is the voltage across the capacitor?
Hint: Use I=dq/dt to relate the net change of flux to the amount of charge that flows to the capacitor.
2. Relevant equations
potential difference = -L dI/dt, where L is the inductance
magnetic field, B = Uo NI/l
total magnetic flux = N (magnetic field for each turn) = N (Area)(B) = (Uo N^2 A I) / l
I = V/R
induced emf = |change in magnetic flux/change in time|
V = Q/C
3. The attempt at a solution
Voltage across the capacitor initially is 0 V, since capacitor is uncharged.
I found the total flux to be 7.85 x 10^-7 Wb.
The changing flux induces an emf.
I'm really stuck here. Can someone please help me? Thanks :)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Jun8-07, 12:22 AM   #2
Quote by ANON View Post
I = V/R
V = Q/C
no time is given? if you're given a time then you have [tex]\frac{d\phi _B}{dt}[/tex] and a voltage
Jun8-07, 05:23 AM   #3
No time is given.
Thread Closed
Thread Tools
Similar Threads for: a coil of wire is connected to an uncharged capacitor in a magnetic field....
Thread Forum Replies
A coil with turns given magnetic field, time find the emf induced in the coil Introductory Physics Homework 4
Magnetic Field at the Center of a Coil Introductory Physics Homework 3
Magnetic field through coil is given by mu*Current/2PI*r, right? Introductory Physics Homework 0
Capacitor connected to a coil inside a magnetic field Introductory Physics Homework 0
magnetic field due to an elliptical coil Advanced Physics Homework 3
