Escaping Earth: Is 25,000 mph the Limit?
  • Context: High School
  • Thread starter Thread starter fluxion
    Earth Limit
The discussion revolves around the concept of escape velocity, particularly in relation to Earth and black holes. Participants explore the conditions under which an object can escape Earth's gravitational influence and the implications of escape velocity in different contexts, including theoretical scenarios involving black holes.
  • Some participants propose that escape velocity is a measure of the speed required to break free from a gravitational field, with a simplified model considering the Earth alone in the universe.
  • Others argue that achieving escape velocity is not the only way to escape; one can use sufficient fuel to gradually ascend and eventually reach a point where escape velocity is much lower.
  • One participant mentions that escape velocity decreases with distance from the gravitational body, allowing for slower escape speeds at greater distances.
  • There is a question raised about whether the inability of light to escape a black hole is due to the black hole's escape velocity being equal to the speed of light, and how this relates to the evolution of stellar remnants like white dwarfs and neutron stars.
  • Another participant suggests that infinite energy may be required to escape a black hole, linking this to the concept that as the mass of a black hole increases, its escape velocity approaches the speed of light.
Participants express varying views on the relationship between escape velocity and the ability to escape gravitational fields, particularly in the context of black holes. There is no consensus on the implications of escape velocity for light and black holes, and the discussion remains unresolved regarding the energy requirements for escaping a black hole.
Participants reference calculations for escape velocity based on gravitational parameters, but the discussion does not resolve the complexities of these calculations or the assumptions involved in different scenarios.
fluxion
Hi all,
(i hope this hasn't been done lately)
But is it true that you can escape from the Earth at any speed - provided you have enough fuel etc.?
And that 25 000 mph is the speed you have to "throw" a Saturn V rocket up at so that it doesn't fall back down?
thanks
david (aka fluxion)
hello fluxion
escape velocity is about getting free from the gravitational influence of something
you simplify it by imagining the Earth (or whatever body) alone in the universe, so there's no competition
then if you go always less than escape velocity then you never escape because no matter how far you get to
when you turn off the engine and stop you will start falling back to earth----or if you have some sideways motion you will go into orbit around earth.
so if you don't achieve escape velocity at SOME distance, you will always be tied to the Earth in some way---falling back or orbiting.
if you want to escape from earth, but do it very slowly like going only 1 kilometer per hour, then you can use a lot of fuel and do it:
you can rise very slowly and keep on rising until you are so far away that
*escape velocity itself is only 1 kilometer an hour*!
Escape velocity declines with distance. so by taking a long time and using a lot of fuel you can achieve a slow escape velocity, but very far away.
but you still achieve escape velocity! If you want to ultimately escape Earth then it is inevitable that eventually you do achieve escape velocity (even if by that time it is a very small velocity)
Use Google to calculate escape from Earth surface----which is "radius of earth" from the center
Put this in the box, and press "search"
sqrt (2*G*mass of earth/radius of earth)
If you type that in the Google window and press search, then Google calculator will give you back
sqrt((2 * G * mass of Earth) / radius of Earth) = 11 180.7201 m / s[/color]
which is 11 kilometers a second
If you want to know the escape velocity at a distance of 300 astronomical units, say, then put this in
sqrt (2*G*mass of earth/(300 astronomical unit))
sqrt((2 * G * mass of Earth) / (300 Astronomical Unit)) = 4.214945 m / s[/color]
that means that if you are already 300 AU from Earth center (in an otherwise empty universe) then escape velocity for you is only 4.2 meters per second. Lucky you, a comparatively slow speed that will not be hard to achieve. Even a bicycle can go 4 meters a second.
Thank you Marcus, that clears it up for me nicely
(and sorry about misplacing that question - my first post)
flux
hi marcus. since fluxion mentioned about escape velocity, does that mean the reason for light unable to escape the black hole is because the black hole's escape velocity is that of the speed of light? thus the EV increases as the sun turns from a white dwarf to a neutron star and lastly a black hole?
That is what I thought, but seeing as marcus said you can escape at any velocity if you have enough "fuel", there must be something else?
Is it just that infinite energy is required to escape a black hole?
you can say so. as the mass of the gravitational body of an object (blackhole) approaches infinity, and/or an objects proximity to the body approaches zero the escape velocity approaches c, the speed of light. however, for black hole theory to be valid the escape velocity must exceed the speed of light as the mass approaches infinity and/or the distance approaches zero.
  • · Replies 18 ·
9K
  • · Replies 42 ·
9K
  • · Replies 38 ·
  • · Replies 39 ·
