Order of integration and differentiation?
The discussion revolves around the order of integration and differentiation, particularly in the context of definite integrals and the use of variables. Participants explore whether the differentiation of an integral with fixed limits can be treated similarly to the differentiation of an integral with a variable limit.
  • One participant questions the validity of the statement that the order of integration and differentiation does not matter, providing an example that leads to confusion over the results.
  • Another participant asserts that the integral of the derivative is likely a different number than the derivative of the integral, suggesting a misunderstanding of the operations involved.
  • Concerns are raised about the use of the variable "x" in the expression, with one participant arguing that it leads to either gibberish or equivocation, as the same symbol cannot represent both a variable of integration and a variable of differentiation.
  • A participant requests clarification on why a dummy variable is necessary in this context, arguing that the function being integrated is dependent on "x" and that it should be acceptable to differentiate with respect to "x".
  • Another participant reiterates the need for a distinct variable of integration to avoid confusion, especially when the limits of integration are functions rather than constants.
Participants express differing views on the necessity of using a dummy variable in the context of definite integrals and the implications of using the same variable for both integration and differentiation. The discussion remains unresolved, with multiple competing perspectives presented.
There is uncertainty regarding the interpretation of variables in the expressions discussed, and the implications of using the same variable for different purposes are not fully agreed upon. The discussion highlights the potential for confusion in mathematical notation and the importance of clarity in variable usage.
Repetit
What am I doing wrong here, I thought the order of integration and differentiation didn't matter in most cases:
[tex] \int_a^b \frac{d}{dx} f(x) dx = \frac{d}{dx} \int_a^b f(x) dx = \frac{d}{dx} (F(b) - F(a)) = 0[/tex]
This is zero no matter what the expression of f(x) because F(a) and F(b) are constants. Am I not allowed to take the differentiation outside the integral when the integral has limits? This is most likely a stupid question for reasons I cannot see.
[tex]\int_a^b f(x) \, dx[/tex]
is just a number, so your result shouldn't surprise you.
[tex]\int_a^b \frac{d}{dx}f(x) \, dx[/tex]
is a (most probably different) number. So I guess the answer to your question is:
[tex]\int_a^b \frac{d}{dx}f(x) \, dx \not= \frac{d}{dx}\int_a^b f(x) \, dx[/tex]
I would like to point out that the three uses of the letter x in
[tex] \frac{d}{dx} \int_a^b f(x) \, dx[/tex]
cannot all possibly refer to the same thing. You have written the mathematical equivalent of either gibberish or equivocation.
gibberish, meaning that it's not a well-formed mathematical expression
equivocation, meaning that you are using the same name for different things, and subsequently treating them as if they were the same thing.
Can you elaborate on this? I mean, it seems like the two inside the integration sign are fine. The function depends on x. It is being integrated with respect to x. And it's just a definite integral...a number. Why can't it be differentiated wrt x as well?
If it were something like this:
[tex]\frac{d}{dx} \int_a^x f(x) \, dx = f(x)[/tex]
then I could see why you'd complain. Some dummy variable of integration should be used:
[tex]\frac{d}{dx} \int_a^x f(t) \, dt = f(x)[/tex]
:confused:
[tex]f(x)=5x^2[/tex]
[tex] \int_a^b f(x) \, dx = \int_a^b (5x^2) \, dx = \frac{5}{3}b^3 - \frac{5}{3}a^3[/tex]
i don't understand how any of that is wrong except for the last part where differentiating a definite integral, which is a number, yields anything but 0
Hurkyl is complaining about the use of the symbol x to denote a dummy variable and a non-dummy variable.
i don't understand what that means?
That's just point of what I was asking! I don't think there *is* a need for a dummy variable in this situation. Didn't anybody read my post #4? I even gave an example of a situation in which you *would* need a dummy variable.
yEA I am with you!
In a definite integral, the symbol dx (or dwhatever) denotes that "x" is a "dummy" variable of integration. The integration variable vanishes once the function is integrated and the integration limits are applied. As Hurkl noted, using the same variable as the variable of integration and outside the integral leads to gibberish. The possibility for confusion become even less greater if the integration limits are functions rather than constants. For this reason, it is preferable to use a notation like cepheid did in post #4. Using a distinct variable of integration becomes mandatory when you do things like
[tex]\frac{d}{dt} \int_{a(t)}^{b(t)} f(t, \tau)\,\mathrm{d}\tau[/tex]
  • · Replies 31 ·
