Common feature of some functions
  • Thread starter Thread starter theriel
    Functions
The discussion revolves around identifying common features of various mathematical functions, specifically focusing on sine, linear, polynomial, and tangent functions. The original poster is tasked with finding derivatives and exploring the relationship between the functions and their derivatives, particularly at the point (0,0).
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to determine if a function intersecting at (0,0) implies its derivative does not, while others question the symmetry of the functions and their derivatives.
Participants are actively exploring the properties of odd functions and their derivatives, with some suggesting that the derivatives of odd functions may be even. There is a mix of attempts to prove these relationships and discussions about generalizing findings.
Participants note the challenge of generalizing findings beyond specific examples and the need to prove relationships between odd functions and their derivatives. There is an emphasis on understanding the implications of function symmetry.
theriel
Hello!
I have a very interesting task, however, at the very beginning I should notice something but... I have a small problem with that ;-].
We have functions:
->sin x,
->5x
->4x7 − 5x3 + 8x
->tan(2x)
I should find their common feature, then find their derivatives and check what do they have in common...
They have different domains, different ranges...
I plotted these function and I have observed:
->f(0)=0 for all these functions
->f(0) does not equal 0 for all their derivatives...
Do you think that this might be the point? Is that a rule that when a function intersects (0,0), its derivative does not?
Or there is something more sophisticated that I cannot see?
Thank you for some hints!
Greetings,
Theriel
f(x)=0?
What are f(1) and f(-1) in all the above?
For functions:
sin(1)=0.841
sin(-1)=-0.841
5x=5
5x=-5
4x^7 − 5x^3 + 8x=7
4x^7 − 5x^3 + 8x=-7
tan(2)=-2.185
tan(-2)=2.185
For derivatives:
cos(1)=0.5403
cos(-1)=0.5403
28x^3-15x^2+8=21
28x^3-15x^2+8=21
2/cos^2x=11,55
2/cos^2x=11,55
Hence we see that when a function is symmetric about (0,0) then its derivative is symmetric about y-axis? :biggrin: Or there is still something more to be found?
So what was the common feature of the functions given? That they have *what* kind of symmetry? (Rotational, reflective?) The first list of functions are examples of ODD functions. They satisfy f(-x)=-f(x). Now, can you show that their derivatives must be EVEN functions?
So:
There is an odd function:
f(-x)=-f(x)
We want to show that its derivative is even, hence:
f'(-x)=f'(x)
f'(x) = lim{h->0} (f(x+h) - f(x))/h
f'(-x)=lim{h->0} ((f(-x+h) - f(-x))/h = lim{h->0} (f(-x+h) - f(x))/h
The problem is how to show that:
f(-x+h)=f(x+h)
knowing that f(-x)=-f(x)... #-/
YOu're over complicating it. (Though what you've done does work.)
What is the derivative of f(2x), f(x^2), and now f(-x) (chain rule)...
Yeah, but the point is that later I will have to generalize and prove the situation. That is why I started doing that part, because proving it for these examples (f(2x), f(x^2) etc.) is easy ;-]. So... could you refer to my small problem in previous post, please?
What? In what way is differentiating both sides of
f(x)=-f(-x)
i.e. where f is an odd function not 'doing the general situation'?
Your previous small problem
f(-x+h)=f(x+h)
can't be done since it is not true that f(-x+h)=f(x+h).
Sorry, I didn't get what you have said #-/. In my task I have to generalize my findings. I found that:
For an odd function "f":
f(-x)=-f(x)
The derivative is even:
f'(-x)=f'(x)
And now the problem is how to prove it. Showing that only for the functions mentioned previously (x^2, tan(2x) etc.) will not be generalization of the situation.
I'm going to repeat this again f is odd means
f(x)=-f(-x)
now for the love of god differentiate both sides of that expression. It is a completely general proof - there is no mention of what f is other than an odd function. Just use the chain rule unless you really must do it from first principles. If you must do it from first principles, then make sure you get the signs right in your limit and it all drops out.
[f(x+h)-f(x)]/h = -[f(-x-h)-f(-x)]/h
now set k=-h, and let k tend to zero and what do you get?
Oh, that was much simpler than I expected... Once again, I am really impressed by the effort and time you spend for helping people solve their mathematical problems... Thank you very much for that!
Greetings,
Theriel
