How do you know for sure what quadrant?
  • Thread starter Thread starter mathzeroh
To determine the quadrant for an angle or normal, one must analyze the signs of the coordinates and use the x-axis as the reference line. In the example provided, the equation -10x + 5 = -5y can be rewritten to show a negative slope, indicating the line is in either the second or fourth quadrant. The y-intercept of 1 confirms the angle is in the second quadrant. The measure of phi is calculated by first finding the reference angle using arctan(2), resulting in approximately 26.57 degrees, and then adjusting for the quadrant, yielding an angle of approximately 333 degrees.
  • Understanding of normal forms in equations
  • Knowledge of trigonometric functions, specifically arctan
  • Familiarity with coordinate geometry and quadrants
  • Ability to manipulate equations to identify slopes and intercepts
  • Study the concept of reference angles in trigonometry
  • Learn about the properties of slopes and intercepts in linear equations
  • Explore the use of inverse trigonometric functions in determining angles
  • Practice identifying quadrants based on coordinate signs and angle measures
Students studying geometry, mathematics educators, and anyone looking to improve their understanding of angles and quadrants in coordinate systems.
mathzeroh
hello all! how do you know for sure which quadrant "they" want you to have your measure in?
for example:
Write each equation in normal form. Then find p, the measure of its normal, and "phi" the angle the normal makes with the positive x-axis.
21.-10x+5=-5y
i've got all the other stuff, it's just that when it comes to the angle measure of "phi," i get sonfused. I don't know how to recognize in which quadrant it should be. for this, I thought that it was this measure:
-26.57...but the correct answer was 333 degrees, approximately.
i know that they got this by adding 360 to -26 degrees, but WHY I don't know. :confused:
thanks in advance for any help
For the original line, the rise over run is 2/1. I'm sure you got that far.
The angle that such a line makes to the horizontal axis is arctan(2).
The angle the normal to that line makes to the horizontal axis is arctan(2) - 90, and it is pointing into quadrant IV, so it can be thought of as a negative angle. That gives you -26.56 degrees, or so says my calculator.
Looking at it as an angle swung counterclockwise (the positive direction of rotation in the plane, by convention) from a ray going horizontally to the right, the angle is 360 - 26.56 = 333.43.
Determining the quadrant for an angle or normal can be tricky, but there are a few key things to keep in mind. First, the x-axis is considered the reference line for angles and normals. This means that any angle or normal is measured from the positive x-axis, which is typically drawn pointing to the right.
To determine which quadrant an angle or normal is in, you need to look at the signs of the coordinates. In the example given, the equation is in the form of -10x+5=-5y, which can be rewritten as y = (-10/5)x + 1.
Since the coefficient of x is negative, the slope of the line is negative. This means that the line will be in either the second or fourth quadrant. To determine which one, you need to look at the y-intercept, which is 1 in this case.
In the second quadrant, both x and y coordinates are negative, so the angle or normal would have a negative slope and a positive y-intercept. In the fourth quadrant, both x and y coordinates are positive, so the angle or normal would have a negative slope and a negative y-intercept.
In this case, the y-intercept is positive, so the angle or normal is in the second quadrant. Now, to find the measure of phi, you need to find the reference angle first. This is the angle formed between the line and the x-axis, measured in a counterclockwise direction.
To find the reference angle, you can use the inverse tangent function (tan^-1) on a calculator. In this case, the reference angle is approximately 26.57 degrees.
To find the actual angle, you need to add or subtract 360 degrees depending on which quadrant the angle is in. In the second quadrant, you need to subtract 360 degrees from the reference angle to get 333 degrees.
In summary, to determine the quadrant for an angle or normal, you need to look at the signs of the coordinates and use the reference line of the x-axis. To find the measure of phi, you first find the reference angle and then add or subtract 360 degrees depending on the quadrant. With practice, you will become more familiar with recognizing the quadrant and finding the correct angle measure.
  • · Replies 21 ·
  • · Replies 16 ·
