Why Isn't {(x,y)|x in Q, y in R} Closed?
  • Thread starter Thread starter pivoxa15
    Closed
The discussion revolves around the set {(x,y)|x in Q, y in R} and its properties in the context of topology, specifically whether it is closed in the R^2 plane. Participants explore the definitions of closed sets and adherent points, questioning the original poster's assertions about the set's closure.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants examine the definition of closed sets and the nature of adherent points, questioning the original poster's reasoning. They discuss the implications of irrational points and the density of rational numbers in the reals.
The discussion is active, with participants providing insights and counterarguments regarding the properties of the set. Some participants suggest reconsidering definitions and examples, while others clarify misunderstandings about adherent points and closures.
There is a focus on the definitions of closed sets and adherent points, with references to the properties of rational and irrational numbers. Participants highlight the importance of understanding density in the context of the set being discussed.
pivoxa15
Consider the set {(x,y)|x in Q, y in R}
This is just a bunch of vertical lines in the R^2 plane. For every point there exists a ball no matter what size which contains another point in this set, namely another point on the same line, dictated by the x value.
So this set contains all its adherent points. However the answers suggested it is not closed (nor open for that matter which is obvious).
Why isn't it closed? Haven't I just shown it is closed?
Uhh... what's the definition of closed? I don't think you have the right one (actually,you've got it backwards... a closed set contains all its adherent points, it isn't a set where all its points are adherent points. Look at an (x,y) where x is irrational and see what you can do)
No it doesn't; it fails for the same reason that the subset Q of R does.
Closed set is where all its adherent points are in the set. Or A=A closure. Or a set that contains all its adherent points as I said in the OP.
I never specified 'a set where all its points are adherent points' is a closed set. In fact this statement is true for open sets as well.
In {(x,y)|x in Q, y in R}, x can't be irrational.
The set A={Q in R} is not closed because (A closure) is the empty set. But A is not empty. Not open because the interior of A is empty whereas A isn't.
But with B={(x,y)|x in Q, y in R}, its different because every adherent point of B is in B.
Pixova, you just verified that if you take a point in the set, it's an adherent point. I asked, what if you take a point not in the set? For example, (x,y) such that x is irrational. Is that an adherent point?
And A closure of Q in R isn't empty, it's just R (as for any point in R, you can find a point in Q infinitely close). That may be the problem you're having
I was trying to say that if any adherent of a set is in the set than that set is closed.
If for any (x,y) such that x is irrational, I can't see how it is an adherent point of {(x,y)|x in Q, y in R}. If a ball centered around x were to contain an x point that is in Q then I can always shrink that radius of the ball so that it contains no points in Q.
No you cannot! Between any two reals you can always find a rational.
So suppose you start with (x,y) and take the ball centered at that point of radius e. Then the horizontal line through (x,y) will contain a copy of the interval (x-e,x+e). This interval contains infinitely many rationals. If you let the radius be e' < e, then the same can be said about (x-e', x+e'), because there is always a rational q such that x-e' < q < x+e'.
The rationals are dense in the reals, after all, i.e. [itex]\bar{\mathbb{Q}} = \mathbb{R}[/itex].
By the way, you previously said that the closure of Q was empty. That should have immediately struck you as absurd, because Q is a subset of its closure. So Q's closure at least contains Q.
Or is the point that between any two irrational points there exist rational pints (in fact infinitely many rational ones). Between two rational points there are infinitely many irrational ones. So the adherent points of the set is R^2.
So {(x,y)|x in Q, y in R} is actually a dense set. So is Q in R.
It is neither open nor closed. Not closed because {(x,y)|x in Q, y in R} is not R^2.
I made my above post before I read Morphisms which pretty much summed up what I had to say. My mistake was in thinking about the natural numbers when I really should have been thinking about the rationals.
