Football player kinematics in one dimension
The problem involves the kinematics of a football player accelerating in one dimension. The player starts from rest, accelerates for a specified time, changes acceleration, and reaches a certain speed. The goal is to determine the initial acceleration during the first phase of motion.
  • Participants discuss the use of kinematic equations to relate time, velocity, and acceleration. Questions arise about the meaning of the given acceleration and how to apply it to the different time intervals.
Participants are actively engaging with the problem, clarifying the role of different accelerations and attempting to apply equations to find the unknown acceleration. Some guidance has been provided regarding the equations to use and the interpretation of the acceleration values.
There is uncertainty regarding the application of the acceleration values and the initial conditions of the problem. The discussion reflects a mix of understanding and confusion about the relationships between the variables involved.
ladolce
A football player, starting from rest at the line of scrimmage, accelerates along a straight line for a time of 3 seconds. Then during a negligible amount of time, he changes the magnitude of his acceleration to a value of 1.1 m/secondssquared. With this acceleration, he continues in the same direction for another 2 seconds until he reaches a speed of 6.4 m/sec. What's the value of his acceleration (assumed to be constant) during the initial 3 sec period?
kinematics
I tried drawing a graph but to no avail. How would I do it with just equations?
You'll have to pick out an equation to use first. As you are given times, velocities and accelerations - something relating the three of those could be handy. Can you find one?
v=vinital+at
but i don't understand what 1.1 m/s sqrd is for...is that the acceleration during the 3sec-5sec time period? i don't know what to plug in
Good equation choice and yes, that's what the 1.1m/sec^2 is. So first concentrate on the 3-5 sec period. You know the final velocity (at 5 sec) and you know the acceleration. Can you determine the velocity at 3 sec? BTW write the equation as v=vinitial+a*(t-tinitial) where tinitial is 3 sec for this time period.
Ok, so I got that stuff plugged in but the acceleration isn't there...what would that be?
Ohhh ok, so 1.1 is the magnitude of the acceleration so that means it IS the acceleration from 3-5 seconds right?
Right. You may find it easier to work with your equation in the form (change of v)=a*(change of t).
Ok, so i got 1.4 m/s^2 but i don't know if that's the right answer? can anyone do it and see what they get/help me? =)
Yes, that's right.
Yay, thank you so much for your help =)
  • · Replies 38 ·
