Finding determinant of Vandermonde matrix
  • Context: Undergrad
  • Thread starter Thread starter strugglinginmat
    Determinant Matrix
The determinant of a Vandermonde matrix can be expressed as the product of differences between its elements. Specifically, for an n x n Vandermonde matrix, the determinant is given by det(V) = C * ∏(a_j - a_i), where the product is taken over 1 ≤ i < j ≤ n, and C is a constant determined to be 1 through induction. The proof involves using Laplace expansion and properties of polynomials, demonstrating that the determinant is a polynomial of degree (n-1) with roots corresponding to the matrix's elements.
  • Understanding of determinants and matrix theory
  • Familiarity with polynomial functions and their properties
  • Knowledge of Laplace expansion in linear algebra
  • Basic concepts of mathematical induction
  • Study the properties of the Vandermonde matrix in detail
  • Learn about polynomial roots and their significance in determinants
  • Explore Laplace expansion techniques for calculating determinants
  • Investigate mathematical induction proofs in linear algebra contexts
Mathematicians, students studying linear algebra, and anyone interested in advanced matrix theory and determinants.
strugglinginmat
Can anyone help with finding the determinant of vandermonde matrix or the way in which I can start the problem. I did with 4X4 matrix but I would have to show that the generalisation that I get works for nXn matrix. Please anyone
It's a bit too messy to write down right now, but try to eliminate a row/column up to a single non-zero member and use Laplace expansion on that row/column and see where it gets you.
This Wikipedia article might help.
http://en.wikipedia.org/wiki/Vandermonde_matrix
The formula is given, but a proof is not given.
To prove the formula given in the article, replace the ith row by
1 x x^2 ... x^(n-1)
Then, take the determinant. The determinant is a function of x. Let's call it
V(x).
It is a polynomial in x of degree (n-1). Hence, it has (n-1) roots. Furthermore, V(a_i) is the value of the vandermonde determinant, and you know that letting x=a_j for any j between 1 and n(excluding i) makes the determinant 0. Hence, a_i is a root of the polynomial V(x). Thus, (a_i - a_j) is a factor in the expansion of V(a_i). Repeating this with each of the i rows tells us that that
det(V)= C product (a_j - a_i), where the product is taken over 1<=i<j<=n. C is a constant. The fact that C=1 follows from induction. To show that C=1, just consider the cofactor expansion along the last column and examine the coefficient of the highest power of a_n. This is again a vandermonde determinant. Hence, C is the same constant as the smaller Vandermonde determinant. Of course, you need to check that in the case n=2 that C=1.
Hope that was clear. I didn't write the solution super carefully, but the ideas are all there... Let me know if it made sense...
  • · Replies 20 ·
  • · Replies 33 ·
