Can AC Motors Function as AC Generators Just Like DC Systems?
  • Thread starter Thread starter unique_pavadrin
    Electric
The discussion revolves around the functionality of AC motors as generators, comparing them to DC systems. Participants explore whether AC motors can operate as AC generators and the relationship between motor speed, voltage, torque, and current.
  • Participants question the conditions under which AC motors might function as generators, contrasting them with DC motors. There is also inquiry into the dependencies of motor speed on voltage and current, and whether these relationships are reciprocal.
Some participants have provided insights into the complexities of AC motor designs and their potential to act as generators, noting that typical AC motors may not function as generators without specific conditions. Others have acknowledged the variety of motor types and their differing capabilities, indicating a productive exploration of the topic.
There is mention of practical limitations regarding typical AC motors and the need for specific designs to enable dual functionality as both motors and generators. The discussion reflects a range of understanding regarding motor operation principles and assumptions about their capabilities.
unique_pavadrin
we have recently started to learn about motors and generators. A DC motor can be a DC generator and vice versa, but is this the case with AC (an Ac motor being an AC generator)? Why or why not?
Also is the speed of the motor dependent upon the voltage and the torque of a motor due to the current supplied to the motor? or is it the opposite? If so why is this the case?
Many thanks to all whom chose to reply,
unique_pavadrin
Yes, an AC motor is definitely possible. There are tricks that you can do with AC power, such as rectifying (that is to say slice up) the wave with a diode, mutual inductance (the idea of transformers), and many other things that open up many possibilities.
Are you asking whether the DC motor speed is proportional to current or voltage? Most likely the answer is yes, but there are so many types of motors out there that I don't want to discount anything.
unique_pavadrin
On a practical level the typical AC motor won't act as a generator. Without some current already flowing through it there is no magnetic field to start the ball rolling as far as generating electricity from a varying magnetic field. DC motors, especially the small kind have permanent magnets.
Now if you have an AC induction motor running and you somehow kicked it into reverse by applying enough torque it will cause a backlash current. But it won't (I don't think) sustain itself as an AC generator. You'll have to design the whole thing differently.
There are AC motor designs which do use permanent magnets and which do like their DC counterparts work both ways as motor and generator. They however aren't as efficient and cost more to build so you won't find them in your typical commercial application.
But in the most general terms your question can't be answered simply as there is a broad range of motor designs with varying ability to work in reverse as generators. (Including the DC ones).
thank you very much for both replies, they have both been of great help, only wish i had a physics teacher as good as
9K
