Maximum amplitude of oscillation of a block
The maximum amplitude of oscillation for a system consisting of a 26 kg block executing horizontal simple harmonic motion with a frequency of 1.9 Hz and a 9 kg block resting on it is determined by the static friction coefficient of 0.459. The force required to overcome static friction is calculated as 40.52 Newtons, leading to a maximum acceleration of 4.5 m/s² for the smaller block. To ensure the smaller block does not slip, the amplitude must be calculated based on this acceleration limit.
  • Understanding of simple harmonic motion principles
  • Knowledge of static friction and its coefficient
  • Familiarity with Newton's second law (F=ma)
  • Ability to perform calculations involving mass, force, and acceleration
  • Calculate the maximum amplitude of oscillation using the formula for acceleration in simple harmonic motion
  • Explore the relationship between frequency and amplitude in oscillatory systems
  • Investigate the effects of varying the mass of the blocks on the system's behavior
  • Learn about energy conservation in simple harmonic motion
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators looking for practical examples of static friction and harmonic motion applications.
Mac13
I've been staring at this problem for a loonnng time and i just can't figure it out:(.. i would appreciate it if someone could help me...thx! :)
A large block with mass 26 kg executes
horizontal simple harmonic motion as it slides
across a frictionless surface with a frequency
1:9 Hz : Block smaller block with mass 9 kg
rests on it, and the
coefcient of static friction between the two is
u = 0.459.
The acceleration of gravity is 9:8.
What maximum amplitude of oscillation
can the system have if the block is not to slip?
Answer in units of cm.
The weight of the smaller block is 9(9.81) = 88.29 Newtons. The force necessary to overcome the static friction, then is (88.29)(0.459)= 40.52 Newtons. Using "F= ma", that would correspond to an acceleration (of the smaller) block of 40.52= 9a or
a= 4.50 m/s2. What amplitude would give a maximum acceleration no greater than 4.5 m/s2?
thanks...its a little too late to turn it in for my homework because it was due early this morning but at least i understand it now:)
  • · Replies 18 ·
  • · Replies 27 ·
11K
